WONDOM AA-AB32166 Class D Amplifier Module TDA7492P
The WONDOM AA-AB32166 is a Class D stereo amplifier module based on the STMicroelectronics TDA7492P chip, designed for integration into active speakers, DIY audio systems, multimedia applications, and OEM projects. Powered by a DC voltage ranging from 10V to 26V, it is capable of delivering up to 2x19W into 8Ω at 1% THD+N and up to 2x25W into 8Ω at 10% THD+N with a 24V power supply.
Reference : 22261
22,90 €tax incl.
19,08 € tax excl.
WONDOM AA-AB32166 Class D Amplifier Module TDA7492P 2x19W 8 Ohm
WONDOM AA-AB32166
The WONDOM AA-AB32166 is a Class D stereo amplifier module based on the STMicroelectronics TDA7492P chip, designed for integration into active speakers, DIY audio systems, multimedia applications, and OEM projects. Powered by a DC voltage ranging from 10V to 26V, it is capable of delivering up to 2x19W into 8Ω at 1% THD+N and up to 2x25W into 8Ω at 10% THD+N with a 24V power supply. Its Class D architecture ensures excellent energy efficiency while minimizing heat generation. The module features a power LED, optimized thermal dissipation through the PCB's large copper areas, as well as overcurrent and thermal protection circuits for reliable operation. It includes stereo analog audio inputs and direct speaker outputs, making integration into a wide range of projects straightforward. Compact with dimensions of 3.6" x 2.7" (approximately 91 x 69mm) and equipped with four mounting points, the AA-AB32166 is a simple, efficient, and cost-effective solution for building low- to medium-power stereo audio amplifiers.
WONDOM AA-AB32166
Overview of the WONDOM AA-AB32166
1Stereo RCA Analog Input
2Stereo Analog Input via Solder Pads
3MUTE/STBY (Solder Pad)
410-26V Power Supply (Solder Pads)
5Stereo Speaker Output
610-26V Power Supply (DC Jack or Screw Terminal)
Technical Specifications
Product TypeAmplifier Module
ClassClass D
Amplifier ChipTDA7492P
Inputs1x Stereo Input via RCA
1x Stereo Input via Solder Pads
Outputs1x Stereo Speaker Output via Screw Terminal
Gain27dB
Input Sensitivity625mV
Input Impedance22Kohms
Output Power2x 19W @8Ω THD+N 1%
2x 25W @8Ω THD+N 10%
Bandwidth20Hz-20kHz @8Ω, ±3dB
THD0.0365% @8Ω, 1W, 1KHz
0.0837% @8Ω, 10W, 1KHz
Noise Level248.93µV
SNR91dB @19W 8Ω THD+N 1%
Minimum Load Impedance8Ω
Power Supply10-26V DC (24V typ.)
Idle Power Consumption0.6-1.2W
Standby Power Consumption0.1-0.5W
Max. Current2.35A @ 50W 8Ohm
Efficiency88.7% @ 25W 8Ohm
Switching Frequency350kHz
Dimensions91 x 69 x 1.7mm
Weight166g / 0.37 lbs (±10%)
Package Contents1x WONDOM AA-AB32166
InputSolder pad
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTDA7492P
Power (W)19.0
WONDOM AA-AB32166 Class D Amplifier Module TDA7492P 2x19W 8 ohm
The WONDOM AA-AB32166 is a Class D stereo amplifier module based on the STMicroelectronics TDA7492P chip, designed for integration into active...
