WONDOM AA-AB32179 Class D Amplifier Module TDA7492 2x38W 6 Ohm
The WONDOM AA-AB32179 is a compact Class D stereo amplifier module based on the STMicroelectronics TDA7492 chip, designed for DIY audio projects requiring high output power and excellent energy efficiency.
Reference : 22265
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 20-11-2026.
WONDOM AA-AB32179
The WONDOM AA-AB32179 is a compact Class D stereo amplifier module based on the STMicroelectronics TDA7492 chip, designed for DIY audio projects requiring high output power and excellent energy efficiency. Powered by a 10V to 27V DC supply (24V recommended), it delivers up to 2x50W into 6Ω at 10% THD+N or 2x38W into 6Ω at 1% THD+N, while maintaining an efficiency ranging from 90% to 95%. Its compact design integrates audio inputs via solder pads, speaker outputs via screw terminals, and a dedicated power supply terminal block. The module features a power indicator, protection against overcurrent, overheating, and reverse polarity, as well as an optimized heatsink ensuring reliable operation. It offers a frequency response from 20Hz to 20kHz, a typical idle power consumption of 1.9W, standby power consumption as low as 0.2W, and a maximum current draw of approximately 4.5A at full power. Thanks to its compact dimensions of 91.4 x 68.6 x 23.9mm, the AA-AB32179 can be easily integrated into active speakers, DIY amplifiers, or embedded audio systems.
WONDOM AA-AB32179
Technical Specifications
Product TypeAmplifier Module
ClassClass D
Amplifier ChipTDA7492
Inputs1x Stereo Input via RCA
1x Stereo Input via Solder Pads
Outputs1x Stereo Speaker Output via Screw Terminal
Gain27dB
Input Sensitivity842mV @6Ω, 50W, 1KHz
Input Impedance22Kohms
Output Power2x 38W @6Ω THD+N 1%
2x 50W @6Ω THD+N 10%
Bandwidth20Hz-20kHz @6Ω, ±3dB
THD0.026% @6Ω, 1W, 1KHz
0.065% @8Ω, 10W, 1KHz
Noise Level314µV
SNR87dB @38W 6Ω THD+N 1%
Minimum Load Impedance6Ω
Power Supply10-27V DC (24V typ.)
Idle Power ConsumptionTyp.: 1.9W
Max.: 5W
Standby Power Consumption0.2-1W
Max. Current4.5A @ 100W 6Ohm
Efficiency90-95% @ 50W @ 6Ohm
Switching Frequency350kHz
Dimensions91.4 x 68.6 x 23.9mm
Weight225g / 0.50lbs (±10%)
Package Contents1x WONDOM AA-AB32179
InputSolder pad
OutputSolder pad
Channel2 (Stereo)
Amplifier chipTDA7492
Power (W)38.0
The WONDOM AA-AB32179 is a compact Class D stereo amplifier module based on the STMicroelectronics TDA7492 chip, designed for DIY audio projects...
