WONDOM AA‑AB32259 DIPO0 Digital Amplifier Module
The Wondom AA‑AB32259 DIPO0 is a stereo digital amplifier with I2S input, designed to ensure direct amplification without intermediate analogue conversion thereby eliminating ground loops and associated interference. It delivers 2 × 2 W power, leveraging fully digital signal path and simplified 3-wire I2S link (MCLK-free), enabling reduction of parasitic emissions. This approach guarantees more stable restitution in sensitive environments, while simplifying integration into embedded systems.
Reference : 22262
11,50 €tax incl.
9,58 € tax excl.
Wondom AA‑AB32259 DIPO0 Digital Amplifier Module 2x2W
Wondom AA‑AB32259 DIPO0 : Front view
Intended for industrial applications and embedded projects — interactive terminals, vending machines, robotics or compact audio — it combines extended power supply of 6.5 V to 60 V with internal buck converter regulation, enabling exploitation of diverse energy sources without external adaptation while maintaining constant operating voltage. This architecture allows coherent amplification in varied contexts, with direct implementation even on heterogeneous power supplies.
Wondom AA‑AB32259 DIPO0 : I2S input
Wondom AA‑AB32259 DIPO0: Unwavering stability
Beyond power supply flexibility, the module integrates thermal and electrical management dimensioned for constrained environments, enabling continuous operation across temperature range of -40 °C to +85 °C without performance drift. This stability extends to increased immunity to power supply variations, guaranteeing constant behaviour even in presence of unstable sources or extreme conditions.
Wondom AA‑AB32259 DIPO0 : Flexible power supply
Wondom AA‑AB32259 DIPO0: Signal and load protection
The AA‑AB32259 integrates anti-distortion circuit monitoring input and power supply conditions, enabling signal deformation limitation in case of overload or voltage drop, translating to direct protection of connected speakers. This approach is completed by comprehensive protections: overcurrent, overheat, undervoltage and polarity reversal, ensuring operational continuity and module reliability over time, including in applications exposed to significant electrical or mechanical constraints.
Wondom AA‑AB32259 DIPO0 : Dimensions and protections
Product typeAmplifier module
Input1x I2S PH 6pins
Outputs1x I2S analogue PH 4pins
1x Speaker terminal molex micro-fit
Gain17.0dB
Noise level220µVrms
Total harmonic distortion (THD)0.05%
Signal-to-noise ratio (SNR)85dB
Frequency response20Hz-20kHz
Supported sample ratePCM 32bit 96kHz
Operating temperature-40℃ ~ 85℃
Storage temperature-10℃ ~ 55℃
Supply voltage6.5-60V DC
Idle current0.012A
Idle consumption0.288W
Dimensions76.2 x 50.8mm
Mounting holes spacing69.9 x 44.5mm
Weight25.5g
Package1x Wondom AA‑AB32259 DIPO0
InputPH 2.0mm
OutputMolex
OutputPH 2.0mm
Channel2 (Stereo)
ClassFDA
Amplifier chipN/A
Power (W)2.0
WONDOM AA‑AB32259 DIPO0 Digital Amplifier Module 2x2W
The Wondom AA‑AB32259 DIPO0 is a stereo digital amplifier with I2S input, designed to ensure direct amplification without intermediate analogue...
