WONDOM AA-AB33511 Amplifier Module
This amplifier module from WONDOM is a powerful 3-channel module. Powerful, it delivers up to 2x300W and 1x 500W @ 3 Ohm (THD+N = 10%). This module is based on Class D architecture and T-AMP technology, enabling 97% efficiency while maintaining high sound reproduction quality and low levels of noise and distortion.
Reference : 18585
99,00 €tax incl.
82,50 € tax excl.
WONDOM AA-AB33511Class D T-Amp Amplifier Module 2x300W + 1x500W 3 Ohm
Photo du WONDOM AA-AB33511
This amplifier module from WONDOM is a powerful 3-channel module. It delivers up to 2x300W and 1x500W under 3 Ohm (THD+N = 10%). This module is based on Class D architecture and T-AMP technology, enabling 97% efficiency while maintaining high sound reproduction quality and low levels of noise and distortion. This multi-channel amplification PCB is therefore ideal for any DIY 2.1-channel audio system project.
The module accepts a power supply range from 24V to 50V DC via DC 5.5/2.5mm jack connector.
Schéma des branchements du module WONDOM AA-AB33511
Wondom AA-AB33511: a high-performance amplifier module
The ingenious design of this PCB by Wondom enables it to achieve excellent performance levels, with SNR as high as 91dB and THD+N as low as 0.01% (3 Ohm, 10W, 1kHz).
Photo d'un système son 2.1 canaux
Photo du ventilateur du module WONDOM AA-AB33511
Wondom AA-AB33511: efficient heat dissipation
This amplifier module features a low-noise fan and an optimized heatsink for optimum cooling of the module during operation. In addition, the module features a complete protection circuit against overheating and overcurrent.
Wondom AA-AB33511: a ready-to-use module
The module's mounting holes allow rapid installation in a case. The PCB features RCA inputs and screw terminals for plug-and-play operation, with no need for soldering.
Photo de la connectique du module WONDOM AA-AB33511
Product typeAmplifier module
Channel number3
Inputs3x RCA input
Outputs3x Unbalanced output on screw terminal block
Output power2x 300W + 1x 500W
Amplification chipT-AMP
Amplification typeClass D
ProtectionsOver/Under-voltage
OPERATING SPECIFICATIONS
ParameterConditionsMinTypMaxUnits
Power supply-2450-VCC
Idle powerSD floating, FAN ON-2025W
SD floating, FAN OFF-16.518W
Standby powerSD connected to GND, FAN OFF-13W
Maximum current600W @ 3Ω-12.6-UN
Efficiency500W @ 3Ω92-97%
Minimum load impedance--2.5-
Switching frequencySD floating-660-KHz
Fan active @ temperature--50-°C
Performances
Gain-28.530.532.5dB
Input sensitivity (RMS)@3Ω, 500W,1KHz-0.876/1.44-V
Input impedance--33-W
Output power@3Ω THD+N 1%-312-W
@3Ω THD+N 10%-500-W
Bandwidth @ ±3dB@3Ω20-20KHz
THD@3Ω, 1W, 1KHz-0.011-%
@3Ω, 10W, 1KHz-0.01-%
Output noise levelA-weighted, Input Connected to GND-224-µV
SNR312W @3Ω THD+N 1%-91-dB
Supply voltage24V - 50V DC
Dimensions152.4 x 101.6mm
Package1x WONDOM AA-AB33511 amplifier module
OutputScrew terminals
Channel3
Amplifier chipT-Amp
Power (W)500.0
Power (W)300.0
WONDOM AA-AB33511 Class D T-Amp Amplifier Module 2x300W + 1x500W 3 Ohm
This amplifier module from WONDOM is a powerful 3-channel module. Powerful, it delivers up to 2x300W and 1x 500W @ 3 Ohm (THD+N = 10%). This module...
