By buying this product you get 71 loyalty points
The Athom Rafale SL1-25 kit is an active subwoofer featuring an S250 MK2-X amplifier module capable of delivering 220W RMS power, coupled with a 23cm LD230TDR04 subwoofer driver covering a frequency range from 30Hz to 150Hz. The result is a subwoofer with surprising performance considering its small size.
Please note: Cabinetry and damping materials are not included.
With the LD230TDR04, Atohm presents a high-quality subwoofer speaker. Drawing on proven know-how and all the expertise acquired during the development and production of previous versions since the LD210, this latest generation of LD230 ‘TDR’ embodies excellence in covering the 20Hz-300Hz band. Thanks to its advanced technologies, this 23cm woofer pushes the limits of a speaker of this diameter to the utmost: unprecedented performance, both in active subwoofer applications and in the bass range of very high-end speakers.
The Atohm S250-MK2-X module combines a 220W Ice Power Class D stage under 4Ω with digital processing specifically designed for active subwoofer applications, incorporating X-GUARD which limits membrane excursion without phase distortion. Two equalisation modes are integrated to suit your needs. CLOSED compensates for the natural rise in impedance in closed loads, and U-GUARD ensures non-saturation of the output while eliminating unwanted harmonics.
| Specifications | |
| Product type | Speaker kit (without cabinet) |
| Inputs | RCA XLR Speaker terminals |
| Frequency response | 30Hz - 150Hz(-3dB) |
| Output power | 220W RMS |
| Sound pressure level | 109dBspl @ 40Hz,PI/2st 1m |
| Load type | Clos 15L |
| Net volume | 13L |
| Speaker | ATOHM LD230TDR04 |
| Amplification module | ATOHM S250-MK2-X |
| Cut-off frequency | 38Hz to 200Hz |
| Filter slope | 12dB/oct or 24dB/oct |
| Phase control | 0°-180° |
| Speaker mechanical protection | X-Guard |
| Voltage limiter | U-Guard |
| Thermal and current protection | |
| General | |
| Power supply voltage | 230V (switchable 115V) / 50-60Hz |
| Dimensions | 260 x 320 x 290mm |
| Weight | 12kg |
| Package | 1x Atohm LD230TDR04 1x Atohm S250-MK2-X 6x M4*30mm screws 6x M4 claw insert 10x Particle board screws 1x ATHOM logo |
