GUSTARD C18 OCXO Clock Black
This high-performance Gustard C18 external clock is ideal for ensuring perfect synchronization of digital audio signals to improve the sound quality of a HiFi system. The C18 is equipped with an ultra-low noise oscillator.
By buying this product you get 159 loyalty points
Reference : 15127
1 599,00 €tax incl.
1 332,50 € tax excl.
Shipping date: 09-07-2025.
Gustard C18
Master Clock OCXO 10MHz Black
Gustard C18 Horloge Maître OCXO 10MHz Noir
OCXO 10MHz
The oscillator used here is a 10MHz OCXO, designed to promote a constant temperature and thus minimize changes in output frequency caused by temperature variation. Specially designed for audio, it allows you to achieve a greater level of detail, a more realistic sound signature and a higher dynamic range.
Independent output stage
The output circuit of the C18 maintains and does not deteriorate the low phase noise signal provided by the main oscillator. The GDRV-P1 can also provide both a sine and a square wave signal to accommodate different devices.
Discrete power supply
The C18 features a discrete Class A power supply circuit that is highly efficient, providing low ripple and fast response.
Product typeMaster clock
Output frequency10MHz
Frequency accuracy< ±300ppb
Frequency stability< ±50ppb
Output amplitude7dBm @ 50Rz
Output waveformSinus
Square
Output impedance50Ω-75Ω (selectable via switch on back of unit)
Bruit @ 1Hz (TYP)-110dBc
Voltage supply115-230V AC 50/60Hz
Consumption< 15W
Dimensions220 x 170 x 50mm
Weight~ 2.5kg
GUSTARD C18 Master Clock OCXO 10MHz Black
This high-performance Gustard C18 external clock is ideal for ensuring perfect synchronization of digital audio signals to improve the sound...
