FIIO FT3 Circumaural Open-Back Dynamic Headphones Ø60mm 32Ω 102dB 7Hz-40kHz
-25%
Fiio offers with the FT3 headphones an aesthetic and performing model, revealing a musical and dynamic sound reproduction with an ergonomic and very modern design. The frequency response is very wide thanks to its open design, which allows to obtain a very vast sound scene in listening. Its sound rendering is very detailed. Design-wise, it is very comfortable thanks to its ergonomic design pivoting on 3 axes.
Reduced price!
Reference : 18768
Limited special offer
279,00 €tax incl.
-25%
209,00 €tax incl.
174,17 € tax excl.
FIIO FT3 Circumaural Open-Back Dynamic Audio Headphones Ø60mm 32Ω 102dB 7Hz-40kHz
FIIO FT3 32 ohm picture
FiiO offers with the FT3 32 Ohms headphones an aesthetic and performing model, revealing a musical and dynamic sound reproduction with an ergonomic and very modern design. The frequency response is very wide thanks to its open design, which allows to obtain a very vast sound scene in listening. Its sound rendering is very detailed. Design-wise, it is very comfortable thanks to its ergonomic design pivoting on 3 axes.
FIIO FT3 32 ohms diaphragm picture
FiiO FT3 32 ohms: Dynamic 60mm drivers
The FT3 of FIIO embarks a large transducer of 60mm of diameter in each ear. This allows it to send a more natural sound and to extend its sound scene. This large transducer allows the FIIO FT3 to go for deeper bass and to support a high power output while keeping a low level of distortion thanks to a beryllium plated suspension edge. The diaphragm is made of DLC (Diamond Like Carbon) which makes it light and rigid at the same time.
In addition, the design uses powerful N52 neodymium magnets to maximize sound quality. They are positioned in an internal and external magnetic circuit in an asymmetrical and optimized way. As a result, the FT3 HiFi headphones are very responsive and dynamic.
Fiio FT3 32 ohms: Open design and low impedance
The open design of the FIIO FT3 headphones delivers detailed audio with clear, precise and natural sound, all with a wide-open soundstage. The headphones' low impedance (32 ohms) and high sensitivity (102db) mean they can be combined with any HiFi source such as a headphone amplifier or audiophile DAP to exploit their full potential. Unlike the FT3 350 Ohms version, it can also be used directly with a smartphone.
FIIO FT3 32 ohms picture
FIIO FT3 32 ohms cable terminaisons picture
FiiO FT3 32 ohms: A high quality cable with interchangeable connectors
The Fiio FT3 cable is 3m long and made of pure Japanese Furukawa single crystal copper with a diameter of 23AWG. It has four interchangeable connectors: two interchangeable plugs of Jack 3.5mm and Jack 4.4mm and two adapters Jack 3.5mm to Jack 6.35mm and Jack 4.4 mm to XLR-4 balanced.
FiiO FT3 32 ohms: Exceptional comfort
Both robust and lightweight, the helmet's frame is made of an aluminum alloy. This makes it a fairly light product for its size with remarkable durability qualities. In terms of wearing comfort, its innovative three-axis swivel design gives it the ability to adapt to all types of body shapes and avoids sound leakage. Finally, the headset comes with two pairs of earpieces, one in suede and one in imitation leather, as well as a hard protective pouch.
FIIO FT3 32 ohms being used
Product typeAudio Headphone
Headphone typeOpen-Back Circumaural
Speakers typeDynamics (Beryllium plated gasket + DLC diaphragm)
Speakers diameterØ60mm
Frequency response7Hz-40kHZ
Sensibility102 dB (1Vrms) @ 1 kHz
Impedance32Ω
ConnectorsCable with 3.5 mm interchangeable plug
Cable with 4.4 mm interchangeable plug
3.5 mm female to 6.35 mm male adapter
Adapter 4.4 mm female to XLR-4 male balanced
Headset pressure 4.0 N ± 0.3 N
CAble
Lenght3m
MaterialFurukawa single crystal copper wire
Headphone connectorsDouble 3,5 mm
Outer shell materialTPE
Shield layerPCOCC-A (26/0.12X2)
Insulation layerPFA
ConductorPCOCC-A (3/20/0,8X2AWG23)
External diameter2.4 mm x 2 (parallel structure)
Weight391g
Package1x Fiio FT3 headset
1x Cable with interchangeable 3.5 mm plug
1x 4.4 mm interchangeable plug
1x Adapter 3.5 mm female to 6.35 mm male
1x Adapter 4.4 mm female to XLR-4 male balanced
1x Storage case
1x Leatherette earpieces
1x Suede ear pads
Impedance (Ω)32
Efficiency / Sensitivity (dB)102.0
Lowest frequency (Hz)7
Highest frequency (Hz)40000
WirelessNo
Cable terminationXLR 4-pin
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Cable terminationJack 4.4mm
Headphone / Earphone connectorJack 3.5mm
Fiio offers with the FT3 headphones an aesthetic and performing model, revealing a musical and dynamic sound reproduction with an ergonomic and...
