FIIO FT3 Circumaural Open Dynamic Headphones Ø60mm 350Ω 102dB 7Hz-40kHz
-25%
Fiio offers with the FT3 headphones an aesthetic and performing model, revealing a musical and dynamic sound reproduction with an ergonomic and very modern design. The frequency response is very wide thanks to its open design, which allows to obtain a very vast sound scene in listening. Its sound rendering is very detailed. Design-wise, it is very comfortable thanks to its ergonomic design pivoting on 3 axes.
Reduced price!
Reference : 17725
Limited special offer
279,00 €tax incl.
-25%
209,00 €tax incl.
174,17 € tax excl.
FIIO FT3
Circumaural Open Dynamic Audio Headphones Ø60mm 350Ω 102dB 7Hz-40kHz
FIIO FT3 Casque Audio Dynamique ouvert Circumaural Ø60mm 350Ω 102dB 7Hz-40kHz
Dynamic 60mm drivers
The FT3 of FIIO embarks a large transducer of 60mm of diameter in each ear. This allows it to send a more natural sound and to extend its sound scene. This large transducer allows the FIIO FT3 to go for deeper bass and to support a high power output while keeping a low level of distortion thanks to a beryllium plated suspension edge. The diaphragm is made of DLC (Diamond Like Carbon) which makes it light and rigid at the same time.
In addition, the design uses powerful N52 neodymium magnets to maximize sound quality. They are positioned in an internal and external magnetic circuit in an asymmetrical and optimized way. As a result, the FT3 HiFi headphones are very responsive and dynamic.
Open design and high impedance
The open design of the FIIO FT3 headphones gives a detailed audio rendering with a clear, precise and natural sound, all this with a wide open sound stage. The high impedance of the headphones (350 ohms) and its high sensitivity (102db) requires it to be associated with a HiFi source with some power such as a headphone amplifier or an audiophile DAP in order to exploit all its capabilities. The use with smartphone is possible but ideally coupled with a portable DAC or portable headphone amplifier.
A high quality cable with interchangeable connectors
The Fiio FT3 cable is 3m long and made of pure Japanese Furukawa single crystal copper with a diameter of 23AWG. It has four interchangeable connectors: two interchangeable plugs of 3.5 mm and 4.4 mm and two adapters 3.5 mm to 6.35 mm and 4.4 mm to XLR-4 balanced.
Exceptional comfort
Both robust and lightweight, the helmet's frame is made of an aluminum alloy. This makes it a fairly light product for its size with remarkable durability qualities. In terms of wearing comfort, its innovative three-axis swivel design gives it the ability to adapt to all types of body shapes and avoids sound leakage. Finally, the headset comes with two pairs of earpieces, one in suede and one in imitation leather, as well as a hard protective pouch.
Product typeAudio Headphone
Headphone typeOpen Circumaural
Speakers typeDynamics (Beryllium plated gasket + DLC diaphragm)
Speakers diameterØ60mm
Frequency response7Hz-40kHZ
Sensibility102 dB (1Vrms) @ 1 kHz
Impedance350 Ω
ConnectorsCable with 3.5 mm interchangeable plug
Cable with 4.4 mm interchangeable plug
3.5 mm female to 6.35 mm male adapter
Adapter 4.4 mm female to XLR-4 male balanced
Headset pressure 4.0 N ± 0.3 N
CAble
Lenght3m
MaterialFurukawa single crystal copper wire
Headphone connectorsDouble 3,5 mm
Outer shell materialTPE
Shield layerPCOCC-A (26/0.12X2)
Insulation layerPFA
ConductorPCOCC-A (3/20/0,8X2AWG23)
External diameter2.4 mm x 2 (parallel structure)
Weight391g
Package1x Fiio FT3 headset
1x Cable with interchangeable 3.5 mm plug
1x 4.4 mm interchangeable plug
1x Adapter 3.5 mm female to 6.35 mm male
1x Adapter 4.4 mm female to XLR-4 male balanced
1x Storage case
1x Leatherette earpieces
1x Suede ear pads
Impedance (Ω)350
Efficiency / Sensitivity (dB)102.0
Lowest frequency (Hz)7
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Cable terminationJack 4.4mm
Cable terminationXLR 4-pin
Headphone / Earphone connectorJack 3.5mm
2 reviews
Excellent rapport qualité/prix
Tout d'abord le "packaging" est tout simplement impeccable.. Les accessoires fournis avec le casque sont de première qualité,
que se soit la connectique (XLR 4, Pentaconn 4, jack 6.5 mmm) ou les oreillettes supplémentaires, le sac en tissu et la petite valise de transport ainsi que le câble de 3 m, tout cela respire une excellente fabrication.
Venons en à l'écoute ! Et bien cela fait maintenant plusieurs heures que j'écoute diverses musiques, classique, jazz, blues etc...et pour l'instant je suis satisfait, la bande passante est très étendue, l'aigu est bien maitrisé, le médium parfaitement en place et le grave est vraiment bon avec une belle diversité. Les instruments comme la contrebasse ou le violoncelle ont du corps. La musique électro a du punch.. Bref le casque est bien équilibré. L'image stéréophonique est large mais sans excés. Maintenant le casque réagit bien aux divers enregistrements, si c'est mal enregistré le casque n'arrangera pas les choses par contre si l'enregistrement est de qualité le casque saura lui rendre grâce. Ceci est l'apanage des bons casques!!
Attention toutefois vu l'impédance de 350 ohms, il faut un ampli costaud pour tirer le maximum, ce casque n'est pas nomade, c'est un casque d'écoute pour la maison. Il a besoin de puissance pour s'exprimer au mieux. Après 3 heures d'écoute d'affilée, pour ma part je n'ai ressentie aucune fatigue, ni échauffement aux oreilles dûs aux coussins. Le port est agréable malgré un poids respectable.
Au regard du prix, de sa qualité de construction et des accessoires fournis est on peut dire un grand merci au constructeur qui a réussi à sortir un casque remarquable à la portée de nombreux mélomanes pas forcément fortunés.
J'ai une très longue expérience de l'écoute au casque, puisque j'ai commencé en 1966 avec un casque Sansui et ensuite j'ai possédé un casque électrostatique Micro Seiki en 1972 et ensuite des casque Stax, Grado, Sony audio techniqua etc... etc...
A l'heure ou les fabricants de casques partent dans délires coûteux et pas toujours à la hauteur (Je sais il en faut pour tous les goûts!!) je trouve cela rassurant de voir que pour une somme raisonnable on peut avoir du matériel de qualité qui offre grandement satisfaction.
 (3)
This review has been posted for FIIO FT3 Circumaural Open Dynamic Headphones Ø60mm 350Ω 102dB 7Hz-40kHz
Un casque au rapport qualité/prix remarquable
Fiio offers with the FT3 headphones an aesthetic and performing model, revealing a musical and dynamic sound reproduction with an ergonomic and...
