FIIO FT1 Headphones
Fiio's FT1 are closed-back dynamic headphones that look as good as they sound. Its dynamic 60 mm diameter drivers coupled with its excellent sound insulation cocoon you in powerful bass. Furthermore, its 32 Ω impedance and high sensitivity make these headphones very easy to drive, ensuring you get the best out of them with a wide range of headphone amplifiers.
4.5 / 5
Reference : 19775
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 02-06-2026.
FiiO FT1 Circumaural Close-back Dynamic Headphones Ø60mm 32Ω 113dB 10Hz - 40kHz
FIIO FT1 : Front view
FiiO's FT1 are closed-back dynamic headphones that look as good as they sound. Its dynamic 60mm diameter drivers coupled with its excellent sound insulation cocoon you in powerful bass. Furthermore, its 32Ω impedance and high sensitivity make these headphones very easy to drive, ensuring you get the best out of them with a wide range of headphone amplifiers.
Fiio FT1: 60mm dynamic drivers
The FT1 is equipped with 60mm-diameter dynamic drivers with nanofibre wood composite diaphragms. This material is created by carefully selecting paper made from Northern European spruce. Once the paper has been selected, it undergoes a process of soaking, cooking and mixing to create a specific pulp. To achieve the required acoustic standards, carbon fibre is added to the mix. Finally, the mixture is baked one last time and then shaped into its final 0.1mm thick form. The FT1's large drivers deliver deep, powerful bass and excellent dynamics.
FIIO FT1 : Driver
FIIO FT1 : Driver
Fiio FT1: Polyurethane suspension
A polyurethane suspension is added to the diaphragm to provide optimum performance. This combination gives the FT1 excellent high-frequency extension, a precise sound and a clear overall timbre. Furthermore, the suspension and diaphragm have been designed together to provide a large surface area for vibration. Compared with other drivers of a similar diameter, the combination developed by Fiio for its headphones provides an average of 25.8% more vibrating surface area. This large surface area minimises vibration losses at the junction between the different materials, reducing distortion caused by the junction of materials between the membrane and the suspension.
Fiio FT1: 25mm CCAW voice coil
The FT1's voice coil has also received special attention. The voice coil is a 25mm diameter CCAW (Copper-Clad Aluminum Wire). Its large size ensures a much more efficient transient response, resulting in a clearer sound reproduction. Furthermore, the coil has been designed to be as light as possible, reducing the total mass of the diaphragm, improving the speed of response and minimising reverberation.
FIIO FT1 : Voice coil
FIIO FT1 : Wooden rear panels
Fiio FT1: Wooden rear panels
The FT1 headphones have top-quality rear panels in black walnut (FAS graded wood). Furthermore, the density of the wood considerably reduces the effects of resonance, cutting short standing waves and the associated distortion.
Fiio FT1: Excellent insulation
To get the most out of your music, the FT1 incorporates a series of sound-absorbing elements to maximise the experience that closed-back headphones can offer. The combination of a U-shaped damping tube, a spiral resonance cavity and a cotton-covered walnut rear cavity for maximum sound absorption gives Fiio's FT1 headphones a sound insulation of -26dB from the outside world.
FIIO FT1 : In use
FIIO FT1 : headphones surrounded by a text giving its sensibility
Fiio FT1: A headphone easy to drive
With the aim of being as flexible as possible, the FT1 has been designed with a low impedance of 32Ω and a high sensitivity of 113dB. As a result, the power required to drive these headphones remains low, allowing them to be adapted to a wide range of configurations without any loss of quality.
Product typeAudio Headphone
Headphone typeCircumaural close-back
Speakers typeDynamics
Speakers diameterØ60mm
Frequency response10Hz - 40kHz
Sensibility98dB/mW @ 1kHz
113dB/Vrms @ 1kHz
Impedance32Ω
Headset pressure4.5N ±0.3N
Headphone connectorDual 3.5mm TRS jack
Cable connectorJack 3.5mm
Jack 4.4mm
Cable conductorSilver-plated OFC copper
Cable length1.5m
Weight340g
ColorWood
Package1xFiio FT1
1x Transport bag
1x 3.5mm jack headphone cable
1x 4.4mm jack headphone cable
1x 3.5mm jack to 6.35mm jack adapter
ColorWood
Impedance (Ω)32
Efficiency / Sensitivity (dB)113
Lowest frequency (Hz)10
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
4 reviews
Excellent pour le prix
Habitué des casques Sony haut de gamme, j'ai été agréablement surpris par la qualité phonique de ce casque ayant de bonne caractéristiques techniques même si je m'attendais à un rendement encore supérieur compte tenu du chiffre annoncé (113 db). Un seul regret : le coffret de transport rigide bien pratique gagnerait à être un petit peu plus grand pour y mettre le casque sans être obligé de retirer à chaque fois les câbles de chaque oreillette pour qu'ils ne soient pas pliés de façon exagérée.
This review has been posted for FIIO FT1 Circumaural Close-back Dynamic Headphones Ø60mm 32Ω 113dB 10Hz-40kHz
Exceptionnel
Un casque d’exception à ce prix. Je recommande. Livré ultra rapidement. Merci.
Bon casque mais quelques défauts casse-pieds
Dans l'ensemble, pour 150€, on ne peut pas reprocher grand chose à ce casque, il est précis et la séparation des voies est bonne.
La scène sonore est par contre moyenne, peu ample ; les basses bien présentes mais peu détaillées.
Le pire est la rigidité du câble. Si vous utilisez un DAC portable, il engendre une contrainte folle sur l'USB.
Enfin, sur la tête, il ne montre pas une tenue très travaillée. Je n'ai pas une petite tête et pourtant, réglé au minimum il tombe presque si je gigote trop.
Fantastic headphones
I can safely say that these headphones will gain cult status. Great sound, the bass is excellent, which I like the most. From the equipment you get with the headphones themselves to the quality of construction and comfort. For this money, you can't do better. You even get a lot more. All recommendations for this model.
And of course I would like to thank the people from Audiophonics, for the quick realization and sending of the product.
Fiio's FT1 are closed-back dynamic headphones that look as good as they sound. Its dynamic 60 mm diameter drivers coupled with its excellent...
