HIFIMAN Deva Pro headphones feature an ultra-thin planar magnetic driver thanks to NsD (“Neo Supernano Diaphragm”) technology. These headphones deliver detailed, clean sound across the entire audible frequency range, yet are easy to drive thanks to their 18-ohm impedance and 94.5dB sensitivity. Lightweight and comfortable, it makes for a highly enjoyable listening experience, even for long sessions. A detachable cable with TRS jack connectors to 3.5mm jack termination accompanies the set. Whether for sedentary or nomadic use, the HIFIMAN Deva Pro is the perfect everyday ally.
The planar magnetic diaphragm in the HIFIMAN Deva Pro headphones features NsD (“Neo Supernano Diaphragm”) technology. This means it's 80% thinner than on the brand's previous designs, for greatly improved transient response, better dynamics and a detailed sound image across its entire frequency range.
The arrangement of the magnets in the HIFIMAN Deva Pro headphones limits their impact on sound reproduction. In fact, the magnets are arranged so as to be acoustically transparent to sound waves, enabling clear rendering while reducing the level of distortion.
Extremely lightweight, HIFIMAN Deva Pro headphones are comfortable to wear for long listening sessions. The earcups are wide enough to completely cover the listener's ears, for excellent passive isolation. Moreover, their memory foam adapts perfectly to every morphology.
HIFIMAN Deva Pro headphones feature 3.5mm jack connectors. A 2x jack 3.5mm TRS to jack 3.5mm termination cable is supplied. However, if you prefer a single cable, this can be achieved by connecting a 3.5mm TRRS jack to the left earcup of the headphones.
Please note that Deva Pro is not compatible with 3.5mm TS jacks.
Product type | Headphone |
Heaphone type | Open-Back |
Headphone format | Circumaural |
Driver | Planar magnetic (NsD - Neo supernano Diaphragm) |
Impedance | 18 ohm |
Sensitivity | 93.5dB |
Frequency response | 20Hz-20kHz |
Headphone connectors | 2x jack 3.5mm TRS or 1x jack 3.5mm TRRS |
Removable cable | |
Cable terminaison | Jack 3.5mm |
Weight | 360g |
Color | Silver |
Package | 1x HIFIMAN Deva Pro headphones 1x Detachable cable 2x jack 3.5mm TRS to termination jack 3.5mm |
Color | Silver |
Impedance (Ω) | 18 |
Efficiency / Sensitivity (dB) | 93.5 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 20000 |
Wireless | No |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | Jack 3.5mm |
