HIFIMAN HE600 Headphones
New
With the HE600, HIFIMAN offers planar magnetic headphone that combine high-quality sound with elegant design. A direct descendant of the HE6, the HE600 features a redesigned magnet array for improved sensitivity, an even thinner diaphragm, and a headband and ear cushions for enhanced comfort.
By buying this product you get 82 loyalty points
Reference : 21107
829,00 €tax incl.
690,83 € tax excl.
Shipping date: 30-09-2025.
HIFIMAN HE600 Open-back Planar Magnetic Circumaural Headphones 28Ω 94dB 8Hz-65kHz
HIFIMAN HE600 : Front view
HIFIMAN HE600: New magnet network design
Here, HIFIMAN's classic stealth magnet array has been further improved, designed to minimise the impact of the magnets on the sound. This array originally allows sound waves to pass through the magnets without creating interference, diffraction or turbulence, ensuring more accurate sound reproduction and wideband reproduction. Furthermore, the new design also optimises the total magnetic power of the array, resulting in sensitivity that rivals rare earth magnets without the need for them.
HIFIMAN HE600 : Magnet array
HIFIMAN HE600 : Ultra-thin membrane
HIFIMAN HE600: Even further thinner membrane
The HE600 headphones also stand out thanks to their diaphragm. This updated version features a diaphragm that is 60% thinner than its predecessor, with a thickness of less than 1 micrometre. This allows it to respond more quickly to impulses while maintaining exceptional detail and extremely low distortion.
HIFIMAN HE600: Improved wearing comfort
When designing the HE600, wearing comfort was also a particular focus. The ear cups on these headphones are made from memory foam covered in velvet to cover your ears as softly as possible. Furthermore, the headband has been redesigned compared to its predecessor to distribute the weight of the headphones evenly while lightening the overall structure. Combined with the weight reduction of other components, the HE600 weighs only 389g, compared to 502g for its predecessor, ensuring long listening sessions without any discomfort.
HIFIMAN HE600 : headband
HIFIMAN HE600 : 3.5mm jack connector
HIFIMAN HE600: 3.5mm jack cable
The HE600 headphone cable is detachable and easily replaceable. It uses standard 3.5mm jack connectors with a 10-degree orientation to reduce pressure on the headphones.
Technical specifications
Product typeHeadphones
Headphone typeOpen-back
Headphone technologyPlanar Magnetic
Frequency response8Hz-65kHz
Impedance28Ω
Sensitivity94dB
Weight389g
ColorSilver
Package1x HIFIMAN HE600
1x 2x 3.5mm jack cable to 3.5mm jack termination
1x 3.5mm to 6.35mm jack adapter
ColorSilver
Impedance (Ω)28
Efficiency / Sensitivity (dB)94.0
Lowest frequency (Hz)8
Highest frequency (Hz)65000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
HIFIMAN HE600 Open-Back Planar Magnetic Circumaural Headphones 28 Ohm 94dB 8Hz-65kHz
With the HE600, HIFIMAN offers planar magnetic headphone that combine high-quality sound with elegant design. A direct descendant of the HE6, the...
