Kiwi Ears Division headphones combine high-quality sound with modern styling. Featuring dynamic 40mm drivers, they deliver balanced bass, neutral mids and clear highs. Lightweight and featuring leatherette-covered ear cushions, Kiwi Ears Division guarantee on-the-go listening comfort with excellent sound performance.
Kiwi Ears headphones have been designed as monitoring headphones. It is therefore focused on professional tuning and has a fairly neutral tonal signature.
The Kiwi Ears Division uses a large 40mm dynamic driver with composite cone for each earpiece. Based on a proven design, the Division's dynamic driver is powerful and precise. Diaphragm tension is adjusted after extensive testing to ensure optimum responsiveness. The voice coil and magnets have also been improved for a richer sound.
The Division is professionally calibrated to deliver transparent reproduction, with punchy bass, neutral mids and detailed highs. The tonal balance of Kiwi Ears Division headphones is designed for precision. Bass has deep impact and rapid decay, guaranteeing a clean, defined sound. Mids remain neutral for precise reference of instruments and vocals, while highs are exceptionally clear and detailed, underlining every nuance without harshness.
Kiwi Ears Division combines classic sound with modern design. Its lightweight structure and comfortable, leatherette-covered earpads make it ideal for use on the move.
The Kiwi Ears Division is a wired headphones designed to deliver excellent sound quality. It therefore comes with a detachable cable with 3.5mm jack termination, as well as a 6.35mm jack adapter.
Product type | Headphones |
Headphones type | Closed-back |
Drivers | Dynamic Ø40mm |
Impedance | 32Ω |
Sensitivity | 98dB +/-3dB |
Frequency response | 20Hz - 20kHz |
Detachable cable | Yes |
Cable termination | Jack 3.5mm (6.35mm jack adapter included) |
Color | Black |
Package | 1x Kiwi Ears Division 1x Jack 3.5mm cable 1x Jack 6.35mm adapter |
Color | Black |
Impedance (Ω) | 32 |
Efficiency / Sensitivity (dB) | 98.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 20000 |
Wireless | No |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | Jack 3.5mm |
Noise reduction | No |
