Très bon produit conforme à toutes mes attentes. Merci Audiophonics.
By buying this product you get 38 loyalty points
The Monolith M1060 headphones are the ideal listening solution to get the most out of your music. Featuring large 106mm Planar Magnetic drivers, the M1060 delivers a precise and rich sound reproduction, allowing you to capture every detail of your music. With a spectacular sound image, low distortion and perfectly balanced sound, the Monolith M1060 is a true audiophile headphone!
Planar Magnetic Drivers
The M1060 is equipped with Planar Magnetic speakers. These have a flat diaphragm directly equipped with magnets. This technology, reserved for high-end headphones, allows a lower level of distortion, a better bass reproduction and a much more accurate sound image. The diaphragms of the M1060 have a large diameter of 106mm.
Over-Ear Open Back Design
The headphones adopt an open design, offering a more open and spacious sound stage than closed headphones that sometimes sound muffled. This makes the M1060's music experience more immersive, putting you at the heart of your music.
Confort
The Monolith M1060 has been designed to provide excellent comfort for long listening sessions. The wide, thick ear cushions and padded headband allow the headphones to be quickly forgotten for a pleasant listening experience.
Product type | Headphone |
Headphone type | Open Back Over-Ear |
Drivers type | Planar Magnetic |
Drivers diameter | Ø106mm |
Magnets structure | Linear symmetry |
Magnets material | Neodymium |
Max power handling | 10W (for 200ms) |
Max SPL | > 130dB |
Frequency response | 10Hz - 50kHz |
THD | < 1% @ 1mW, 1kHz |
Impedance | 50Ω |
Efficiency | 96dB/1mW |
Optimal power | 200mW - 4W |
Cable length | 1.90m |
Weight | 500g |
Package | 1x Monolith M1060 1x Braided Jack 3.5mm cable 1x Jack 3.5mm to Jack 6.35mm adapter 1x Transport bag |
Color | Walnut |
Color | Black |
Impedance (Ω) | 50 |
Efficiency / Sensitivity (dB) | 96.0 |
Lowest frequency (Hz) | 10 |
Highest frequency (Hz) | 50000 |
Wireless | No |
Cable termination | Jack 6.35mm |
Cable termination | Jack 3.5mm |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Philippe B.
Vesa N.
Francis A.
