The Moondrop Horizon is an open-back headphone based on a 50mm dynamic driver specially developed by the brand for this model. This new driver is accompanied by an N55 dual magnet magnetic circuit, a combination that delivers a frequency response very close to the VDSF curve, resulting in very present bass, soft treble and a natural overall tone.
The Horizon headphones feature the brand new driver developed by Moondrop. The result of two years of research, this 50mm dynamic driver benefits from improved dynamic range, reduced distortion and extended frequency response.
To achieve good high-frequency extension with a 50mm diaphragm, it is essential to find the right balance between rigidity and damping. To meet this requirement, Moondrop has developed a titanium-plated polyethylene naphthalate (PEN) dome coupled with a silica gel suspension. This combination provides both excellent rigidity and response speed while offering significant movement amplitude and damping to the diaphragm.
This brand new driver is coupled with a custom-developed magnetic circuit, using two N55 magnets instead of a traditional single magnet design. This results in a magnetic power of 1.85T, allowing the new driver design to be used to its full potential.
In order to create a wider sound stage and ensure spatial consistency, the Horizon features a brand new driver tilt structure, allowing sound waves to reach the ear at an oblique angle. This technique promotes a more natural diffusion of sound waves within the acoustic cavity, offering a wider sound stage and authentic timbre.
Thanks to its new driver design, the Horizon's frequency response follows the VDSF target curve beautifully, delivering rare sub-bass performance for a dynamic driver and high frequencies that are very gentle on the ear.
The Horizon features a 3.5mm jack connection, making it compatible with a wide range of cables on the market. Furthermore, the supplied cable has an interchangeable termination, allowing you to easily switch between a single-ended 3.5mm jack output and a balanced 4.4mm output, depending on your devices and preferences.
Product type | Headphone |
Headphone type | Open-back |
Headphone format | Circumaurale |
Driver | Dynamique 50mm |
Headphone connectivity | Jack 3.5mm |
Cable terminations | Jack 3.5mm asymétrique Jack 4.4mm symétrique |
Frequency response | 20Hz-34kHz |
Impedance | 32Ω ±15% @ 1kHz |
Sensitivity | 109dB |
Total harmonic distortion (THD) | ≤ 0.1% @ 1kHz 94dB |
Color | Black |
Package | 1x Moondrop Horizon 1x Headphone cable 1x 3.5mm jack termination 1x 4.4mm jack termination 1x Pair of ear pads |
Color | Black |
Impedance (Ω) | 32 |
Efficiency / Sensitivity (dB) | 109 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 34000 |
Wireless | No |
Cable termination | Jack 3.5mm |
Cable termination | Jack 4.4mm |
Headphone / Earphone connector | Jack 3.5mm |
