MOONDROP HORIZON Headphone
The Moondrop Horizon is an open-back headphone based on a 50mm dynamic driver specially developed by the brand for this model. This new driver is accompanied by an N55 dual magnet magnetic circuit, a combination that delivers a frequency response very close to the VDSF curve, resulting in very present bass, soft treble and a natural overall tone.
Reference : 20982
186,90 €tax incl.
155,75 € tax excl.
Moondrop Horizon Open-Back Dynamic Headphone 32 Ohm 109dB 20Hz-34kHz
Moondrop Horizon : Front view
Moondrop Horizon: 50mm dynamic driver
The Horizon headphones feature the brand new driver developed by Moondrop. The result of two years of research, this 50mm dynamic driver benefits from improved dynamic range, reduced distortion and extended frequency response.
Moondrop Horizon : Cutaway view of the driver
To achieve good high-frequency extension with a 50mm diaphragm, it is essential to find the right balance between rigidity and damping. To meet this requirement, Moondrop has developed a titanium-plated polyethylene naphthalate (PEN) dome coupled with a silica gel suspension. This combination provides both excellent rigidity and response speed while offering significant movement amplitude and damping to the diaphragm.
Moondrop Horizon : mesure du circuit magnétique
This brand new driver is coupled with a custom-developed magnetic circuit, using two N55 magnets instead of a traditional single magnet design. This results in a magnetic power of 1.85T, allowing the new driver design to be used to its full potential.
Moondrop Horizon: Système d’inclinaison des haut-parleurs
In order to create a wider sound stage and ensure spatial consistency, the Horizon features a brand new driver tilt structure, allowing sound waves to reach the ear at an oblique angle. This technique promotes a more natural diffusion of sound waves within the acoustic cavity, offering a wider sound stage and authentic timbre.
Moondrop Horizon : Tilt system
Moondrop Horizon: Frequency response close to the VDSF curve
Thanks to its new driver design, the Horizon's frequency response follows the VDSF target curve beautifully, delivering rare sub-bass performance for a dynamic driver and high frequencies that are very gentle on the ear.
Moondrop Horizon : Frequency response curve
Moondrop Horizon : 3.5mm and 4.4mm jack termination
Moondrop Horizon: Câble à la terminaison interchangeable
The Horizon features a 3.5mm jack connection, making it compatible with a wide range of cables on the market. Furthermore, the supplied cable has an interchangeable termination, allowing you to easily switch between a single-ended 3.5mm jack output and a balanced 4.4mm output, depending on your devices and preferences.
Product typeHeadphone
Headphone typeOpen-back
Headphone formatCircumaurale
DriverDynamique 50mm
Headphone connectivityJack 3.5mm
Cable terminationsJack 3.5mm asymétrique
Jack 4.4mm symétrique
Frequency response20Hz-34kHz
Impedance32Ω ±15% @ 1kHz
Sensitivity109dB
Total harmonic distortion (THD)≤ 0.1% @ 1kHz 94dB
Package1x Moondrop Horizon
1x Headphone cable
1x 3.5mm jack termination
1x 4.4mm jack termination
1x Pair of ear pads
Impedance (Ω)32
Efficiency / Sensitivity (dB)109
Lowest frequency (Hz)20
Highest frequency (Hz)34000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 4.4mm
Headphone / Earphone connectorJack 3.5mm
MOONDROP HORIZON Open-Back Dynamic Headphone 32 Ohm 109dB 20Hz-34kHz
The Moondrop Horizon is an open-back headphone based on a 50mm dynamic driver specially developed by the brand for this model. This new driver is...
