With the Edge, Moondrop offers us a wireless, LDAC-compatible Bluetooth headphone featuring a low-distortion 40mm driver with a titanium-plated composite cone for highly defined, naturally textured sound. These headphones benefit from all Moondrop's expertise in noise suppression, including hybrid ANC and beamforming reduction during phone calls.
The Edge is based on a 40mm dynamic driver. This driver incorporates a composite diaphragm with flexible suspension and a titanium-plated dome, ensuring excellent definition and a natural low-midrange texture. This diaphragm is accompanied by a CCAW voice coil and N52 magnetic circuit, guaranteeing low distortion and excellent dynamic range. Furthermore, this driver benefits from a custom acoustic cavity specially designed to get the best out of it, while isolating this part from the electronic circuits to avoid any interference.
The Edge's active noise suppression is based on a hybrid FF + FB (Feedforward + Feedback) technology, using both the surrounding noise and an analysis of the signal produced to elaborate a phase signal opposite to the noise detected. Furthermore, a transparency mode is also available, so you can listen to your favorite tracks while being aware of your surroundings.
Furthermore, to provide effective noise reduction during telephone calls, the Edge is equipped with four microphones for beamforming noise reduction. This technique relies on several microphones picking up the same sound source. However, due to their different placements, the interference picked up by each of these microphones will be different, enabling them to be discriminated and suppressed.
To ensure stable signal transmission in any situation, the Edge includes the largest possible Bluetooth antenna, enabling it to maintain a perfect connection even in the most complex electromagnetic environments. Furthermore, the Singer is compatible with the Bluetooth LDAC codec, enabling high-resolution, broadband transmission of your favorite song.
To follow you wherever you go, Edge is equipped with a 48-hour battery. This is coupled with a fast-charging system that recharges the equivalent of 4 hours of listening in just 5 minutes.
Particular attention has been paid to ergonomics and wearing comfort in the design of the Edge. The ear cushions are made of memory foam and shaped to fit the shape of the skull. Moreover, for greater practicality in transport, this helmet is equipped with a folding aluminum temple, both aesthetically pleasing and durable.
Edge's headphones have been designed to offer a frequency response as close as possible to that of the VDSF model. Furthermore, thanks to the MOONDROP Link application available for Android and iOS, you can choose from several frequency response models, leaving more or less room for low frequencies.
Product type | Wireless headphones |
Bluetooth version | 5.4 |
Bluetooth transmission protocol | ADP / AVRCP / HFP / HSP |
Supported Bluetooth codecs | SBC / AAC / LDAC |
Charging port | USB-C |
Operating distance | 15m (barrier-free open environment) |
Driver | 40mm dynamic driver |
Recharge time | 1.5h |
Autonomy | 48h |
Color | White |
Package | 1x Moondrop X Singer Edge 1x USB-A to USB-C cable 1x Carrying bag |
Color | White |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 20000 |
Wireless | Yes |
Cable termination | Wireless |
Headphone / Earphone connector | USB |
Headphone / Earphone connector | Wireless (Bluetooth) |
