MOONDROP X SINGER EDGE Wireless Headphones White
With the Edge, Moondrop offers us a wireless, LDAC-compatible Bluetooth headphone featuring a low-distortion 40mm driver with a titanium-plated composite cone for highly defined, naturally textured sound. These headphones benefit from all Moondrop's expertise in noise suppression, including hybrid ANC and beamforming reduction during phone calls.
Reference : 20081
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 05-05-2026.
Moondrop X Singer Edge Dynamic Wireless Headphones Ø40mm Bluetooth 5.4 LDAC 20Hz - 20kHz White
Moondrop Singer : Front view
Moondrop Singer : Summary of key features
Moondrop X Singer Edge: 40mm dynamic driver
The Edge is based on a 40mm dynamic driver. This driver incorporates a composite diaphragm with flexible suspension and a titanium-plated dome, ensuring excellent definition and a natural low-midrange texture. This diaphragm is accompanied by a CCAW voice coil and N52 magnetic circuit, guaranteeing low distortion and excellent dynamic range. Furthermore, this driver benefits from a custom acoustic cavity specially designed to get the best out of it, while isolating this part from the electronic circuits to avoid any interference.
Moondrop Singer : Composition Driver
Moondrop Singer : Noise reduction
Moondrop X Singer Edge: ANC / ENC / Transparency mode :
The Edge's active noise suppression is based on a hybrid FF + FB (Feedforward + Feedback) technology, using both the surrounding noise and an analysis of the signal produced to elaborate a phase signal opposite to the noise detected. Furthermore, a transparency mode is also available, so you can listen to your favorite tracks while being aware of your surroundings.
Furthermore, to provide effective noise reduction during telephone calls, the Edge is equipped with four microphones for beamforming noise reduction. This technique relies on several microphones picking up the same sound source. However, due to their different placements, the interference picked up by each of these microphones will be different, enabling them to be discriminated and suppressed.
Moondrop X Singer Edge: Excellent Bluetooth connectivity
To ensure stable signal transmission in any situation, the Edge includes the largest possible Bluetooth antenna, enabling it to maintain a perfect connection even in the most complex electromagnetic environments. Furthermore, the Singer is compatible with the Bluetooth LDAC codec, enabling high-resolution, broadband transmission of your favorite song.
Moondrop Singer : Bluetooth antenna
Moondrop Singer : Autonomy
Moondrop X Singer Edge: Autonomy and fast charging
To follow you wherever you go, Edge is equipped with a 48-hour battery. This is coupled with a fast-charging system that recharges the equivalent of 4 hours of listening in just 5 minutes.
Moondrop X Singer Edge: Ergonomics and wearing comfort
Particular attention has been paid to ergonomics and wearing comfort in the design of the Edge. The ear cushions are made of memory foam and shaped to fit the shape of the skull. Moreover, for greater practicality in transport, this helmet is equipped with a folding aluminum temple, both aesthetically pleasing and durable.
Moondrop Singer : Macro view of an ear pads
Moondrop X Singer Edge: VDSF model
Edge's headphones have been designed to offer a frequency response as close as possible to that of the VDSF model. Furthermore, thanks to the MOONDROP Link application available for Android and iOS, you can choose from several frequency response models, leaving more or less room for low frequencies.
Moondrop Singer : Frequency response
Product typeWireless headphones
Bluetooth version5.4
Bluetooth transmission protocolADP / AVRCP / HFP / HSP
Supported Bluetooth codecsSBC / AAC / LDAC
Charging portUSB-C
Operating distance15m (barrier-free open environment)
Driver40mm dynamic driver
Recharge time1.5h
Autonomy48h
ColorWhite
Package1x Moondrop X Singer Edge
1x USB-A to USB-C cable
1x Carrying bag
ColorWhite
Impedance (Ω)NC
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationWireless
Headphone / Earphone connectorWireless (Bluetooth)
Headphone / Earphone connectorUSB
MOONDROP X SINGER EDGE Dynamic Wireless Headphones Ø40mm Bluetooth 5.4 LDAC 20Hz-20kHz White
With the Edge, Moondrop offers us a wireless, LDAC-compatible Bluetooth headphone featuring a low-distortion 40mm driver with a titanium-plated...
