By buying this product you get 44 loyalty points
Headphone Planar Magnetic Over-Ear 32Ω 98dB 20Hz-40kHz
After 3 years of research and development, optimizations and innovations, the planar magnetic P-II headphone from Sivga is here. A high performance model, using high quality components and benefiting from an elaborate design, based on the use of a wooden envelope. The P-II is equipped with planar magnetic drivers with 97 x 67mm composite diaphragms, which have been designed to offer a balanced and natural reproduction, coherent over the whole frequency range, while being able to reveal many details and a large sound stage.
The planar magnetic drivers are combined here with Sivga's OTC technology. With their ultra-thin composite diaphragms and aluminum-plated circuitry, the P-II's drivers are very thin and light. The dual magnets and 108 perfectly arranged perforations also provide excellent airflow. A design that promotes a beautiful dynamic and rich sound.
Based on extensive data from big data on the shape of many people's faces and heads, Sivga was able to optimize the P-II's ear cushions with a unique slanted design, allowing for a perfect seal between the headphone and the wearer, but also a perfect fit. The space inside the ear cushions forms an oval, allowing the headphones to surround the ear. Each pad is made of high quality leather and a soft, comfortable velvet-like fabric.
The P-II's headband is made of stainless steel, while the headphone attachments are made of aluminum. The headband uses a leather cover with a curved and padded design to limit pressure on the head. The headband is also adjustable to fit all body types. Practical, the earphones can swivel on themselves up to 90°.
The shell of the headphones combines walnut wood and CNC machined metal parts. This wood was selected for its acoustic properties and its aesthetics. A beautiful perforated grille finishes the P-II, giving it a luxurious design.
The P-II cable, detachable, uses 6N copper conductors, ensuring a perfect transmission of the signal. Its input connector is a 4.4mm jack. A 4.4mm female to 3.5mm male jack adapter is also provided.
| Specifications | |
| Product type | Headphone |
| Headphone type | Over ear |
| Transducer type | Planar magnetic |
| Dimensions Transducer size | 97 x 76mm |
| Frequency response | 20Hz - 40kHz |
| Sensitivity | 98dB ±3dB |
| Impedance | 32Ω ±15% |
| Cable length | 1.6m ±0.2m |
| Cable connector | Jack 4.4mm |
| General | |
| Finish | Black walnut |
| Weight | 420g |
| Package | 1x Sivga P-II 1x Jack 1.6m cable 1x Jack 4.4mm to Jack 3.5mm cable 1x Carrying case 1x Cable bag |
| Color | Walnut |
| Impedance (Ω) | 32 |
| Efficiency / Sensitivity (dB) | 98.0 |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 40000 |
| Wireless | No |
| Cable termination | Jack 6.35mm |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | Jack 3.5mm |
