AUDIOPHONICS HC Trigger Home-Theater to HiFi system switcher 12V
The Audiophonics HC is a home-theater trigger whose primary benefit is to save you the trouble of changing cable connections between your hi-fi system and your home-theater system. The trigger function also triggers the power supply to your home cinema system.
Reference : 18233
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 17-07-2025.
AUDIOPHONICS HC
Trigger Home-Theater Power Trigger 2x12V
AUDIOPHONICS HC Trigger Home-Theater Power trigger 2x12V
The Audiophonics HC is a Home-Theater trigger whose first benefit is to save you the trouble of changing cable connections between your Hi-Fi system and your home-cinema system. The trigger function also triggers the power supply to your home-theater system. It features an RCA priority input for your Hi-Fi system, an RCA stereo input for your home-theater system and an RCA stereo output for a power amplifier. Two 12V triggers with 3.5mm jack connectors are also included. One trigger switches signal transmission to your home-theater system when you switch on your home-theater amplifier, and the second automatically switches on your power amplifier.
TRIGGER OFF (Hi-Fi application)
By adding Audiophonics HC to your Hi-Fi system, the Hi-Fi system takes priority. You can use your Hi-Fi system connected to your passive speakers normally without disconnecting or reconnecting any cables if you have used your home-theater system previously. Simply switch off your home-theater system.
TRIGGER ON (Home-Theater application)
If you switch on your home-theater system, it will take over thanks to an internal switch triggered by the link between your home-theater amplifier and the Audiophonics HC via a 3.5mm trigger cable. Your power amplifier connected to your front speakers will also switch on thanks to the second 12V trigger. So you don't need to change the wiring of your "front speakers", whether for use with your Hi-Fi or Home-theater system.
The rear panel of the Audiophonics HC Home-Theater Trigger
Product typeHome-Theater Trigger
Inputs1* RCA stereo input for Hi-Fi installation
1* RCA stereo input for home-theater installation
Outputs1* RCA stereo output
Trigger2* 3.5mm jack
Trigger cable type3.5mm jack to 3.5mm jack mono
Operating trigger voltage12V / 10mA
Dimensions (LxPxH)152*103*44 mm (H = 50mm with feet)
Weight390g
Package1* AUDIOPHONICS HC Trigger
Output voltage (V)12.0
Output current (A)NC
Input voltage (V)12.0
Power SupplyTrigger
3 reviews
You miss a little detail
Just put a diode 1N4007 in the jack plug so you can use a jack spliter in your amp (hifi and avr)
This review has been posted for AUDIOPHONICS HC Trigger Home-Theater to HiFi system switcher 12V
Top!
Fonctionne parfaitement entre un pré ampli cinéma et une installation hi-fi. Très simple pour les branchement. Aucun bruits dans les enceintes. Parfait. Comme toujours, audiophonics au top !
Au top
Voici le genre d’accessoires très pratique au quotidien.
Deux installations un ampli de puissance. Plus besoin de débrancher/rebrancher son installation.
A l’usage pas de souffle perçu sans musique, la bascule se fait automatiquement.
A recommander.
A quand une version qui ajoutera la fonction de symetrisation du signal ?
The Audiophonics HC is a home-theater trigger whose primary benefit is to save you the trouble of changing cable connections between your hi-fi...
