sehr gutes Kabel.........mehr Transparenz und Präzision im Sound
Neotech NEI-3001G is a balanced interconnect cable incorporating 4 G-UPOCC copper conductors 99.99998% pure. It benefits from a top-of-the-range design with two single-core and two multi-strand conductors. In addition, graphene is used to greatly improve the conductivity of this cable's G-UPOCC copper conductors.
Dielectric insulators are a clever mix of alternating polyethylene (PE) air tubes within a symmetrical design. This design minimizes capacitance effects. The PE conductors and tubes are held in place by PTFE insulating tape, preventing the transmission of electrical and static discharges created by the double Mylar/aluminium shielding and OCC copper foil. The whole assembly is encased in a sheet of paper with cotton fibers for mechanical strength, then covered with a robust, flexible PVC sheath.
| Specifications | |
| Product type | Balanced interconnect cable |
| Conductor material | UP-OCC copper with graphene (G-UPOCC) |
| Conductors | 2x single-core conductors 2x multi-strand conductors |
| Insulation | 5 polyethylene tubes PTFE tape PVC outer sheath |
| Shielding | AL MYLAR aluminum foil OCC braided copper foil Textile paper |
| External diameter | Ø10.5mm |
| General | |
| Color | Blue |
| Package | Sold by the meter |
| Diameter (mm) | 10.5 |
| Number of conductors | 4 |
| Insulation material | PTFE |
| Insulation material | PE |
| Shielding | Yes |
| Section (mm²) | N/A |
| Conductors Plating (Cable) | None |
| Ground / Shielding | Yes |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Erhard B.
Peter C.
Attila R.
