NEOTECH NEI-3002G Balanced Interconnect Cable
The Neotech NEI-3002G is a balanced interconnect cable utilising two G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor represents a significant breakthrough, both in terms of research and industrial applications. Indeed, the addition of graphene improves the stability of electrical signal transmission at high temperatures whilst preserving the exceptional conductivity of OCC copper, ensuring that performance remains intact even at high voltages.
Reference : 21686
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 24-11-2026.
Câble vendu au mètre
Neotech NEI-3002G Balanced Interconnect Cable Shielded G-UPOCC Copper Graphene 0.69mm² Ø10.3mm
NEOTECH NEI-3002G : Front view
NEOTECH NEI-3002G : Composition
The conductors are insulated with polyethylene foam, which, together with the double shielding of copper-clad Mylar and braided copper, prevents any electrical discharge from being transmitted, whilst also giving the cable good mechanical strength.
Product typeBalanced interconnect cable
Conductor materialUP-OCC copper with graphene (G-UPOCC)
Conductors cross-section0.69mm² (~19AWG)
InsulationPolyethylene foam (PE)
ShieldingOFC Copper
Copper alloy
Outer sheathPVC
Outer diameterØ10.3mm
ColorBlue
PackageSold by the meter
Diameter (mm)N/A
Number of conductors2
Insulation materialPE
ShieldingYes
Section (mm²)N/A
Conductors material (Cable)Graphene
Ground / ShieldingYes
NEOTECH NEI-3002G Balanced Interconnect Cable Shielded G-UPOCC Copper Graphene 0.69mm² Ø10.3mm
The Neotech NEI-3002G is a balanced interconnect cable utilising two G-UPOCC composite conductors, a combination of OCC copper and graphene. This...
