BFA Banana Plugs Gold Plated Ø4mm (Pair)
These low-cost BFA banana plugs allow for quick and easy design of speaker cables. The assembly is done by means of a screwing system, effectively holding the conductor in the banana plug. In addition, they provide good conductivity and durability thanks to gold-plated copper alloy contacts.
Reference : 17525
2,60 €tax incl.
2,17 € tax excl.
BFA Banana plugs
Gold plated Ø4mm (Pair)
Fiches bananes BFA plaquées or Ø4mm (La paire)
These low-cost BFA banana plugs allow for quick and easy design of speaker cables. The assembly is done by means of a screwing system, effectively holding the conductor in the banana plug. In addition, they provide good conductivity and durability thanks to gold-plated copper alloy contacts. The design of this banana plug also allows for a clean contact with the connector.
Product typeBFA banana plugs
Contacts materialCopper alloy
Contacts platingGold 3µ
Max cable diameterØ4mm
Mounting typeTo screw
Total dimensionsØ7.8*42mm
Max cable diameter (mm)4.0
ConnecticMale
ConnectorBanana
Bananes
fiches bananes d'excellente qualité, le contact avec les borniers est parfait. Montage facile !!!
This review has been posted for BFA Banana Plugs Gold Plated Ø4mm (Pair)
These low-cost BFA banana plugs allow for quick and easy design of speaker cables. The assembly is done by means of a screwing system, effectively...
