ETI LINK BANANA BAYONET Banana Plug Gold Plated Beryllium Copper Ø9mm (Set x4)
The ETI Link Banana plugs offer excellent design quality to facilitate signal transmission. The contacts are made of gold-plated Copper Beryllium, ensuring very good conductivity and resistance to oxidation.
Reference : 14613
135,00 €tax incl.
112,50 € tax excl.
Shipping date: 19-03-2026.
ETI LINK BANANA bayonet
ETI LINK BANANA Fiches Banane Cuivre Béryllium Plaqué Or Ø9mm (Set x4)
The ETI Link Banana plugs offer excellent design quality to facilitate signal transmission. The contacts are made of gold-plated Copper Beryllium, ensuring very good conductivity and resistance to oxidation. Their design ensures a good contact between the banana plug and the terminal block. The body of the connectors is made of Aluminium, which is both robust and protects the signal from EMI/RFI interference.
The ETI Link Banana accepts cables up to 9mm in diameter. Assembly is extremely simple with two Torx screws, without the need for welding.
Product typeBanana plugs
MaterialBeryllium Copper
PlatingGold
Body materialAluminium
Mounting2 Torx screws
Max. cable diameterØ9mm
QuantitySold by 4 units
Max cable diameter (mm)9.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
Contacts Material (Connector)Beryllium Copper
The ETI Link Banana plugs offer excellent design quality to facilitate signal transmission. The contacts are made of gold-plated Copper Beryllium,...
