SPEAKER SNAP Gold Plated Banana Plugs Ø4mm (Pair)
These Speaker Snap banana plugs are gold-plated for optimum resistance to corrosion and erosion. They also feature an extremely practical mounting system that requires no tools.
Reference : 17951
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 16-07-2025.
SPEAKER SNAP
Gold-plated Banana plugs (Pair)
SPEAKER SNAP Fiche banane Plaquée Or (La paire)
Simple, quick and innovative mounting
To mount this banana plug on your bare cable, simply insert the cable into the banana plug and press the lever to lock it in place. All that's left to do is connect the cable to your speakers, amplifier or other HiFi equipment. This innovative mounting system, which is still not widely used in the audio world, has a number of advantages. In particular, it's extremely easy to mount and provides a solid connection between the cable and the banana plug.
Compatible with a wide range of cables
These Speaker Snap banana plugs are compatible with cables with conductors from 12AWG (Ø2mm / 3.3mm²) to 24AWG (0.5mm / 0.2mm²).. The total diameter of the cable to be inserted with its sheath must not exceed 4mm.
Product typeBanana plug
Contact materialCopper alloy
Contact platingGold
Body materialHeat resistant thermoplastic
Mounting typeBy pressing a lever
Acceptable conductor diameter2mm (12AWG) à 0.5mm (24AWG)
Total acceptable cable diameter4mm
Dimensions (LxH)45 x 15 mm
Weight4g
Package2x Speaker Snap banana plug
Max cable diameter (mm)4.0
Mounting typeWith lever
ConnecticMale
ConnectorBanana
2 reviews
bon produit , bon site.
bonjour, produit reçu en bonne état, correspond a la description, efficace a l'usage. je suis satisfait de mon achat sur votre site.
This review has been posted for SPEAKER SNAP Gold Plated Banana Plugs Ø4mm (Pair)
bananes mais pas banales !
belle qualité pou ces fiches banane utilisation de grande simplicité et contact parfait lors du raccordement tant du coté câble que du coté ampli ! Parfait .
These  Speaker Snap banana plugs  are gold-plated for optimum resistance to corrosion and erosion. They also feature an...
