VIBORG BFA Banana Plugs 24k Gold Plated Ø8.5mm (Set x4)
These Viborg banana plugs benefit from a nice design quality and a low price. The contacts are made of a gold-plated copper alloy ensuring good conductivity and durability. The body is made of aluminum.
4.8 / 5
Reference : 15739
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 08-08-2025.
Viborg BFA Banana Plugs
Gold Plated Ø8mm (Set x4)
Viborg Fiches Bananes Plaqué Or Ø8mm (La paire)
These Viborg banana plugs benefit from a nice design quality and a low price. The contacts are made of a gold-plated copper alloy ensuring good conductivity and durability. The body is made of aluminum. Each plug can accept cables up to 8mm in diameter. Mounting is very simple thanks to a screw system.
Product typeBanana plugs
Contacts materialCopper alloy
Contacts platingGold
Body materialAluminum
Max cable diameterØ8mm
Max conductor diameterØ4.5mm
Mounting typeTo screw
Dimensions46.7 x 10.7mm
QuantitySold by 4 (2x red / 2x black)
Max cable diameter (mm)8.0
ConnecticMale
ConnectorBanana
13 reviews
tres moyen
J' ai essayé ces fiches de qualités moyennes voir en dessous. le signal est assez passant mais la qualité de serrage et de fabrication n e fait pas honneur a Viborg même à ce tarif.
This review has been posted for VIBORG BFA Banana Plugs 24k Gold Plated Ø8.5mm (Set x4)
Viborg ?
Rien a voir avec la qualité habituelle de Viborg. Des vis indevssables, un corps d' habillage très cheap. Cependant, la fiche de contact semble de qualité au regard du tarif
Best affordable BFA bananas
Nothing to complain of - great bananas with great fit to speaker terminals. Easy to work with and they look good aswell. 5 stars easily.
Very nice plugs for the price, that fitted nicely in my Focal Chora 816's.
Très bien pour le prix, une des deux vis d'une fiche tournait dans le vide et je n'ai pu l'enlever. Sinon permet de bien serrer mon cable de section 4mm2.
These Viborg banana plugs benefit from a nice design quality and a low price. The contacts are made of a gold-plated copper alloy ensuring good...
