WM AUDIO HB301Z Modular Connector Body Ø6mm (Pair)
This connector for loudspeaker is very efficient. Its screw thread allows the adaptation on 3 different types of compatible plugs in option:
Specifications:
Compatible with the following banana or fork terminations:
W&M Audio HEAD-B301G Banana Terminations:
W&M Audio HEAD-HB301G Banana Terminations:
Terminaisons Fourches W&M Audio HEAD-K301G :
| Max cable diameter (mm) | 6.0 |
| Mounting type | To screw |
| Connectic | Female |
| Connector | Banana |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
