Connector
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Accepts Banana Plugs
Max panel thickness
mm
mm
Bruno R.
Alain p.
top du top
OGUZHAN O.
With Bluesound Node N130
I use it with Bluesound Node N130 and it gave lots of sound improvements
Binding Posts & Terminals
Discover our range of speaker terminals, alone or mounted on a plate, for the design of your speakers or HiFi amplifiers.
  • Binding Posts
    Binding Posts
    Discover our range of speaker terminals (without mounting plate) for the design of your speakers or amplifiers.
  • Speaker terminals
    Speaker terminals
    Discover our range of speaker terminals mounted on plates or mounting brackets, for the design of your HiFi speakers.
