J'ai deja utilisé ces borniers , je les trouve de bonne qualité et bon serrage.
Gold Plated Binding Post ⌀15mm x 57mm (Pair)
The Dayton Audio BPA-38G HD terminal blocks have been designed to help ensure proper signal reproduction. Thus, the contact material is 24K gold plated, ensuring both very good conductivity and excellent oxidation resistance.
In addition, these terminals can accommodate cables up to 3.26mm in diameter (8AWG) or banana plugs for an easier connection. The large diameter notched head allows easy grip for improved ergonomics.
The long screw pitch of the terminal block allows integration on panels up to 25.4mm thick. In addition, the notched part inside will prevent the connector from rotating on itself.
Plating | Gold 24k |
Max panel thickness | 25.4mm |
Cutout diameter | 6.35mm |
Accepts banana plugs | Yes |
Total length | 57mm |
Max diameter | 15mm |
Connection type | To solder |
Color | Gold |
Mounting type | To weld |
Connectic | Female |
Max panel thickness (mm) | 6.0 |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Gilbert H.
Gilbert H.
Nikolaos R.
Benoit C.
David B.
