By buying this product you get 34 loyalty points
Speaker Terminals Gold Plated Copper (Set x4)
Since it is known that a simple electrical wire is no longer sufficient to connect an amplifier and speakers, we have become accustomed to using cables with large cross sections, which has had some repercussions on the terminal blocks. There are two requirements for this type of connector: it is not only a question of accepting large cable cross-sections, but above all of ensuring excellent conductivity by means of extreme tightening. The truth is therefore not in the giant terminal blocks, but rather in the mechanical design of the connector, which is extremely robust.
The integrated retaining mechanism (WBT patent) holds the banana plug firmly in place when the front locking nut is tightened and thus not only protects the connection against accidental disconnection but also ensures extremely high contact pressure.
| Specifications | |
| Product type | Speaker terminals |
| Material | Copper (68%) Alloy |
| Plating | Gold 24k |
| Conception | Machined in the mass |
| Max support thickness | 10mm |
| Length | Speaker terminal: 31mm Total length (avec pas de vis) : 58mm |
| Max. speaker terminal diameter | Ø21mm |
| Weight (per speaker terminal) | 60g |
| Package | 4x Terminal WBT-0702.01 |
| Mounting type | To screw |
| Connectic | Female |
| Max panel thickness (mm) | 10.0 |
| Accepts Banana Plugs | Yes |
| Connector | Speaker terminal |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
