XANGSANE XS-T072 Gold-Plated Speaker Terminals (Set x4)
Xangsane's XS-T072 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 7mm and a minimum of 3mm. Connectors are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation.
Reference : 18157
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 15-09-2026.
XANGSANE XS-T072
XANGSANE XS-T072 Borniers haut-parleur Plaqués Or (Set x4)
Xangsane's XS-T072 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 7mm and a minimum of 3mm. Non-slip joints are provided for mounting. Connectors are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation. Internal cable assembly is by soldering, while on the other side, these terminal blocks accept either spades (Ø6/8mm) or banana plugs (Ø4mm).
Product typeSpeaker terminals
Contact materialCopper alloy
Contact platingGold
Min. mounting panel thickness3mm
Max. mounting panel thickness7mm
Mounting screw thread8mm
Compatible connectorsBanana plugs (Ø4mm)
Spades (Ø6/8mm)
Internal cable mountingTo weld
Identification rings
Total dimensions50 x Ø16mm
PackageSet x4
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)7.0
Accepts Banana PlugsYes
ConnectorBanana / Spade
Xangsane's XS-T072 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 7mm and a...
