XANGSANE XS-T075 Gold-Plated Speaker Terminals (Set x4)
Xangsane's XS-T075 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 20mm and a minimum of 3mm. Connectors are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation.
Reference : 18160
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 29-09-2026.
XANGSANE XS-T075
Xangsane's XS-T075 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 20mm and a minimum of 3mm. Non-slip joints are provided for mounting. Connectors are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation. Internal cable assembly is by soldering, while on the other side, these terminal blocks accept either spades (Ø6/8mm) or banana plugs (Ø4mm).
Product typeSpeaker terminals
Contact materialCopper alloy
Contact platingGold
Min. mounting panel thickness3mm
Max. mounting panel thickness17mm
Mounting screw thread8mm
Compatible connectorsBanana plugs (Ø4mm)
Spades (Ø6/8mm)
Internal cable mountingTo weld
Identification rings
Total dimensions66 x Ø16mm
PackageSet x4
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)17.0
Accepts Banana PlugsYes
ConnectorBanana / Spade
Xangsane's XS-T075 speaker terminals are ideal for mounting on enclosures with a maximum thickness of 20mm and a minimum of...
