Bluetooth 5.0 CSR8675 aptX-HD DAC ES9018 24bit 48kHz Module
This small and powerful DAC module is based on an ESS ES9018K2M conversion chip, allowing for quality signal decoding. A chip that has already proven itself on many products, renowned for the accuracy and richness of the audio message it delivers.
4.3 / 5
Reference : 13863
54,90 €tax incl.
45,75 € tax excl.
Last items in stock !
Shipping date: 15-05-2026.
Module DAC ES9018 Bluetooth
DAC ES9018K2M Bluetooth 5.0 CSR8675 aptX-HD 24bit 48kHz
Module DAC ES9018 Bluetooth 5.0 CSR8675 aptX LDAC 24bit 96kHz
However, the main advantage of this module is most probably its Bluetooth 5.0 input, allowing you to stream your files remotely, directly from your smartphone. In addition, the integrated CSR8675 Bluetooth chip supports aptX and aptX-HD technologies, improving throughput and transmission stability. These protocols support sampling rates up to 24bit 48kHz. A Bluetooth antenna is also provided to increase the reception range of the module.
On the output side, this is done on two PH 2.0mm 3-pin connectors, an OPA2604AP AOP to amplify the output signal. This AOP is mounted on DIP8 and can therefore be modified according to your listening preferences.
Product typeDAC Module
DAC ChipES9018K2M
Output1x Stereo AUX
Bluetooth chipCSR8675
Bluetooth version5.0
Supported Bluetooth technologiesaptX, aptX-HD
Supportes sampling rateUp to 24bit 48kHz
Dimensions67 x 33mm
Fixation holes spacing56 x 27mm
Power supply5-32V DC (Sold separately)
Package1x Bluetooth ES9018 DAC module
2x PH 2.0mm to bare wires (3 wires) cable
1x PH 2.0mm to bare wires (2 wires) cable
1x SMA Antenna
1x U.FL to SMA Cable adapter
OutputXH 2.54mm
OutputPH 2.0mm
DAC / ADC ChipES9018K2M
Max sampling rate96kHz
Channel2 (Stereo)
3 reviews
Bon produit, mais descriptif érronée (AOP5532 JRC), pas de notice d'utilisation
J'ai voulu équiper mon préampli avec du bluetooth et ayant vu les autres avis j'ai donc pris ce module.
Le produit est bien fait, son corret, mais l'AOP n'est pas un OPA2604AP comme indiqué dans le descriptif, mais un JRC5532.
J'ai voulu utiliser l'alimentation de mon préampli, mais mauvaise idée, le module réinjecte du bruit assez important sur le circuit d'alimentation. il faut soit rajouter une self pour courant continue supérieur à 2.2H, ou alors mettre une alimentation séparé.
J'ai utilisé une 10H en 0.3A
L'appairage se fait très facilement.
Pas de notice d'utilisation, dommage, le module peut accepter une alimentation de 40V max (Tension max du régulateur)
à 12V celui-ci consomme moins de 100mA)
Pour le cablage :
Une entrée d'alimentation
Une entrée audio
Une sortie audio
Deux leds bleu pour informer de l'appairage
This review has been posted for Bluetooth 5.0 CSR8675 aptX-HD DAC ES9018 24bit 48kHz Module
Fonctionnement parfait
acheté pour être intégré dans une enceinte mobile en cours de réalisation, je l'ai essayé sur ma chaine hifi, la mise en oeuvre est très simple, aucun paramétrage, le téléphone l'a détecté instantanément et le son tout à fait correct, j'ai l'intention d'en acheter un second pour une autre réalisation
Excellent produit
Installé dans un préamp Rotel, ce module BT me donne pleine satisfaction.
Bonne qualité, fonctionne en 12v sans problème.
This small and powerful DAC module is based on an ESS ES9018K2M conversion chip, allowing for quality signal decoding. A chip that has already...
