LINKPLAY WiFi LAN Receiver A31 DLNA UPnP IR Remote
This very practical WiFi receiver module proposed by LinkPlay is ideal for integration into a DIY creation and will allow you to easily broadcast your audio files while enjoying your WiFi or LAN network.
4.5 / 5
Reference : 13874
59,90 €tax incl.
49,92 € tax excl.
This product is temporarily unavailable.
LinkPlay Récepteur WiFi
WiFi LAN Receiver A31 IR Remote
LinkPlay Récepteur WiFi LAN A31 Télécommande IR
This very practical WiFi receiver module proposed by LinkPlay is ideal for integration into a DIY creation and will allow you to easily broadcast your audio files while enjoying your WiFi or LAN network. The module comes with an antenna to improve its WiFi reception, as well as a remote control for remote control and all the cables needed to make the connections. In addition, the module is fully controllable using a free mobile application such as Müzo or iEast Play. These even allow you to take advantage of the multiroom since it is possible to use several modules in different rooms of your house and to control the reading in a synchronized way or not directly.
The module also includes an Ethernet RJ45 network input, an audio input and output on PH 2.0mm connectors and a WPS button to connect the module to the network very easily and quickly.
Application WiiM Home
This free mobile app, available on both Android and iOS, will allow you to easily and remotely control the playback of your music, with an area management system. By connecting to your local network, you can then choose the files stored on your computer / NAS, on your smartphone or use streaming services such as Qobuz, Spotify or Tidal.
iEast Play Google Play Store Android iEast Play App Store iOS
WiiM Home App
Le service de streaming Qobuz n'est disponible que sur l'application iEast Play.
Schéma module
Module diagram
1Power indicator
2RJ45 plug
3Status indicator
4Power input
GND : Ground
5V : Power output 5V
5Power light indicator
D+ : Status LED
D- : Power LED
L : Line left input
R : Ligne right input
A : Line sensing
G : Ground
6Audio output
R : Right output
G : Ground
L : Left output
M : Mode
W : WPS
M : Mute
7U Disk Interface
5V DC - USB Vcc 800mA
DP : Data +
DM : Data -
GND : Ground
8IR Receiver
9WPS Button
10A31/A28 Interfaces
Remote control
1Power button
2Mode : AUX input / WiFi
3Mute
4Play all
5Play / Pause
6Volume +
7Volume -
8Previous
9Next
10Presets 1-6
Product typeWiFi Receiver
InputsWiFi
Ethernet RJ45
OutputPH 2.0mm Connector
WiFi Receiver ModuleLinkPLay A31
IR Remote Control
WiFi Antenna
DLNA / UPnP Support
Power supply5V DC on XH 2.54mm connector (power supply sold separately)
Package1x WiFi Receiver module
1x Remote control
1x WiFi Antenna
1x XH 2.54mm 2 pins cable
1x PH 2.0mm 4 pins cable
2x PH 2.0mm 6 pins cable
Dimensions71 x 42 x 17mm
Fixation holes spacing49 x 36mm
InputRJ45
InputWiFi
OutputPH 2.0mm
2 reviews
petite precision pour utilisation du port USB
Le connecteur (7) 4 pins prevu pour connecter un peripherique USB n'est pas cable correctement. Les 2 contacts mileu (DP data+ DM data-) sont inverses. Tel quel, le module ne reconnait pas les cles USB ou supports de stockage. Il suffit de croiser les fils et ca marche parfaitement avec IeastPlay!
This review has been posted for LINKPLAY WiFi LAN Receiver A31 DLNA UPnP IR Remote
Compact et fonctionne parfaitement avec iEastplay vtuner & Qobuz.
Comme toujours avec Audiophonics, recu tres rapidement apres la commande et bien conditionne. Les 2 exemplaires fonctionnent fort bien avec iEastplay en config solo ou multi room sync.
Mais attention, a part la description des connecteurs, il n'y a aucune notice d'utilisation et de configuration de premiere utilisation.
Tres similaire au lecteur reseau iEast soundstream-pro M30 (sortie SPIDF en moins) soit vous vous rapportez a sa notice technique https://www.audiophonics.fr/fr/index.php?controller=attachment&id_attachment=333
soit vous vous connectez la premiere fois en Wifi directement sur le player qui apparait dans les connexions sous le nom CNXXX et ensuite dans votre navigateur en appelant l'adresse 10.10.10.254 vous pouvez configurer les differents parametres en commencant par la connexion WiFi du player a votre reseau domestique, puis le nom de l'appareil etc... en navigant dans les tabs.
Petite cerise sur le gateau, tout comme son frere iEast, la relecommande permet de programmer 6 touches de preset, tres pratique.
This very practical WiFi receiver module proposed by LinkPlay is ideal for integration into a DIY creation and will allow you to easily broadcast...
