Bluetooth 5.0 Receiver Board QCC3031 aptX HD TWS U.FL
The TinySine AudioB TSA6179 is a Bluetooth 5.0 stereo receiver board, based on a Qualcomm QCC3031 chip that can be integrated into many DIY projects to provide your devices with a wireless reception function. It integrates a micro USB port to update the firmware and two buttons that can be assigned to different functions.
| Pin # | Name | Direction | Description |
| 1 | GND | - | Ground |
| 2 | SPK_LP | Analog output | Speaker output, positive, left channel |
| 3 | SPK_LN | Analog output | Speaker output, negative, left channel |
| 4 | SPK_RP | Analog output | Speaker output, positive, right channel |
| 5 | SPK_RN | Analog output | Speaker output, negative, right channel |
| 6 | GND | - | Ground |
| 7 | LINEIN_LN | Analog input | Line input, negative, left channel |
| 8 | LINEIN_LP | Analog input | Line input, positive, left channel |
| 9 | LINEIN_RN | Analog input | Line input, negative, right channel |
| 10 | LINEIN_RP | Analog input | Line input, positive, right channel |
| 11 | VIN | - | Supply voltage +5V (+3.7V à +5.5V) |
| 12 | - | - | - |
| 13 | SPK_R | Analog output | Speaker output, right channel |
| 14 | SPK_L | Analog output | Speaker output, left channel |
| 15 | 3.3V | - | Output voltage +3.3V |
| 16 | AGND | - | Analog ground |
| 17 | FORWARD | Input | Next track |
| 18 | REWIND | Input | Previous track |
| 19 | PLAY/PAUSE | Input | Play / Pause |
| 20 | AUX_DET | Input | Activation of automatic line input detection (Aux in) |
Single-ended output
Single-ended output with headphone/small speakers
Differential output
The TSA6179 provides two firmware options: TWS Mode and Party Mode (multipoint). The firmware can be updated via the micro USB port of the module :
First use :
TWS Connection
Master board :
Slave board :
Party Mode Connection
Master board :
Slave board :
| Specifications | |
| Product type | Bluetooth receiver board |
| Bluetooth version | 5.0 |
| Bluetooth chip | QCC3031 |
| Supported Bluetooth codecs | aptX aptX HD |
| Multipoint connection | |
| Qualcomm cVC technology (noise cancellation) | |
| Qualcomm TrueWireless technology | |
