1MII B06S+ Bluetooth 5.2 Receiver
New
The 1Mii B06S+ is a Bluetooth 5.2 receiver designed to add wireless streaming to a Hi-Fi system, an amplifier or an active speaker. It supports the LDAC, aptX HD and aptX Low Latency codecs, with an LDAC bitrate of up to 990 kbps and a stated resolution of 24 bit/96 kHz, allowing music to be received from a compatible smartphone.
Reference : 22573
42,90 €tax incl.
35,75 € tax excl.
Shipping date: 17-11-2026.
1MII B06S+: Front view
The 1Mii B06S+ is a Bluetooth receiver 5.2 designed to add wireless streaming to a Hi-Fi system, an amplifier or an active speaker. It supports the LDAC, aptX HD and aptX Low Latency codecs, with an LDAC bitrate of up to 990 kbps and a stated resolution of 24 bit/96 kHz, allowing music to be received from a compatible smartphone.
Its RCA and 3.5 mm jack outputs make it easy to integrate into existing audio systems, while the light ring indicates the decoding format in use. The stated range of 15 to 30 m allows listening across several rooms, depending on obstacles and interference. Once paired, the device reconnects automatically; its controls also allow you to adjust the volume and change tracks.
Technical features
Product typeBluetooth receiver
InputsBluetooth
Outputs1x stereo RCA
1x 3.5mm Jack
Supported Bluetooth codecsLDAC
aptX HD
aptX Low Latency
Bluetooth version5.2
Supported sampling ratesPCM 24bit 96kHz
Supply voltage5V DC
Package1x 1MII B06S+
1x USB-A to DC Jack power cable
1x stereo RCA to 3.5mm Jack cable
OutputJack 3.5mm
DAC / ADC ChipNC
Download
The 1Mii B06S+ is a Bluetooth 5.2 receiver designed to add wireless streaming to a Hi-Fi system, an amplifier or an active speaker. It supports the...
