1MII B06T3+ Bluetooth 5.2 Receiver
New
The 1Mii B06T3+ is a Bluetooth 5.2 receiver designed to add a wireless input to a Hi-Fi system, an amplifier or an active speaker. It decodes the LDAC, aptX, SBC and AAC codecs, with support rated up to 24bit/96kHz and an LDAC bitrate reaching up to 990 kbps, allowing you to receive music from a phone, tablet or laptop.
Reference : 22566
34,90 €tax incl.
29,08 € tax excl.
1MII B06T3+: Front view
Its RCA and 3.5 mm jack outputs can be used simultaneously to connect two audio devices. The rated latency of 30 ms favors synchronization during playback, while the integrated rotary control allows you to adjust the volume and control playback. Compact, the B06T3+ thus integrates into an existing audio system without replacing its amplification components.
Technical specifications
Product typeBluetooth receiver
Inputs1x Bluetooth
Outputs1x stereo RCA
1x 3.5mm Jack
Supported Bluetooth codecsaptX
aptX HD
aptX Low Latency
LDAC
AAC
SBC
Bluetooth versionBluetooth 5.2
Supply voltage5V DC
Package1x 1Mii B06T3+
1x 3.5mm Jack to stereo RCA cable
1x USB-A to DC Jack power cable
OutputJack 3.5mm
DAC / ADC ChipNC
Supported Bluetooth codecsSBC
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
Download
The 1Mii B06T3+ is a Bluetooth 5.2 receiver designed to add a wireless input to a Hi-Fi system, an amplifier or an active speaker. It decodes the...
