Receiver Transmitter Bluetooth 5.0 aptX HD CSR8675
The 1Mii B03+ is an extremely versatile and high-performance Bluetooth transmitter and receiver at an affordable price. Its intelligent and careful design allows it to ensure high quality sound reproduction, notably thanks to a high-performance Bluetooth chip and a conversion stage based on a DAC proven and recognized by audiophiles.
aptX Low Latency technology eliminates the delay when transmitting audio over Bluetooth for perfectly synchronized listening. The Dual Link function allows it to be broadcast over two headsets or two speakers in a fully synchronized manner.
With support for the aptX HD Bluetooth transmission codec, the 1Mii B03+ is capable of delivering sound quality at least equal to that of a CD, wirelessly.
Using Bluetooth Class 1 technology and integrating two antennas, the B03+ can reach transmission/reception distances of up to 30m (without obstacles).
The 1MII B03+ is equipped with an LED display. It allows to clearly display the detected and connected Bluetooth devices as well as other information such as the volume level.
At the heart of the 1Mii B03+ is a Qualcomm CSR8675 Bluetooth 5.0 chipset, a high-performance solution designed to ensure high-quality audio reproduction. It ensures clean and stable signal transmission and reception.
The B03+, in addition to its Bluetooth connectivity, offers a 3.5mm jack and Toslink Optics as inputs and outputs.
Versatile, the 1Mii B03+ can be used in 3 different modes, in order to adapt to everyone's needs: receive, transmit and bypass.
Transmitter mode
The 1Mii B03+ can be used as a Bluetooth transmitter. In this mode, you can transmit an audio stream to an audio device, TV, AV receiver, headphones, speakers or any other audio source device with Bluetooth connectivity.
Receiver mode
In receiver mode, the B03+ can receive a Bluetooth audio stream from a connected device, such as a smartphone, tablet or computer.
Bypass mode
Finally, the bypass mode connects an input directly to an output, with the receive and transmit functions disabled. Bypass mode allows the device to be used in DAC (Digital to Analog Converter) mode, or ADC (Analog to Digital Converter) mode.
Product type | Bluetooth Transmitter / Receiver |
Inputs | Bluetooth 5.0 1x Optical Toslink 1x Jack 3.5mm |
Outputs | Bluetooth 5.0 1x Optical Toslink 1x Jack 3.5mm |
Bluetooth chip | Qualcomm CSR8675 |
DAC Chip | - |
Bluetooth version | 5.0 |
Supported Bluetooth profiles | A2DP AVRCP |
Supported Bluetooth codecs | SBC AAC aptX aptX LL aptX HD |
Max transmission distance | Obstacle-free: 30m |
Général | |
Color | Black |
Package | 1x 1Mii B03+ 1x USB-A to Micro USB cable 1x Jack 3.5mm to RCA cable 1x Jack 3.5mm cable 1x Optical cable 1x Power supply |
Input | Optical |
Input | Jack 3.5mm |
Input | Bluetooth |
Output | Jack 3.5mm |
Output | Optical Toslink |
Output | Bluetooth |
DAC / ADC Chip | ES9018Q2C |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | SBC |
