1MII LAVAUDIO DS220 Bluetooth 5.1 Receiver QCC5125 DAC ES9018K2M aptX Adaptive LDAC
This small, practical and compact 1Mii Lavaudio DS220 Bluetooth 5.1 receiver brings wireless connectivity to your HiFi system. Its high-quality design is based on the combination of a Qualcomm 5125 Bluetooth receiver and an ES9018Q2M DAC chip, enabling you to enjoy precise sound reproduction even when wireless.
Reference : 18181
145,00 €tax incl.
120,83 € tax excl.
1Mii Lavaudio DS220
1Mii Lavaudio DS220 Récepteur Bluetooth 5.1 QCC5125 DAC ES9018K2M aptX Adaptive LDAC
This small, practical and compact 1Mii Lavaudio DS220 Bluetooth 5.1 receiver brings wireless connectivity to your HiFi system. Its high-quality design is based on the combination of a Qualcomm 5125 Bluetooth receiver and an ES9018Q2M DAC chip, enabling you to enjoy precise sound reproduction even when wireless. The receiver also supports the high-resolution transmission codecs aptX, aptX HD, aptX Adaptive and LDAC, ensuring excellent sound quality over Bluetooth. The DS220 also features a small OLED display on the front panel, showing information such as the active input, the codec used, the sampling rate of the current stream or the selected filter.
Product typeBluetooth receiver
Bluetooth chipQualcomm QCC5125
DAC chipESS ES9018K2M
InputsBluetooth 5.1
1* USB-C
Outputs1* Optical Toslink
1* Stereo RCA
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, aptX Adaptive, LDAC
Supply voltage5VDC 1A (power supply included)
Housing materialAluminum
Dimensions76*87*25mm
Weight110g
Package1* 1Mii Lavaudio DS220
1* Bluetooth antenna
1* 5V 1A Power supply
1* Power cable
1* USB-A to USB-C cable
1* Optical Toslink cable
1* RCA to Jack 3.5mm cable
1* RCA cable
OutputOptical Toslink
DAC / ADC ChipES9018K2M
Supported Bluetooth codecsaptX
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
2 reviews
Étonné
Pour completer mon precedent avis, le Ds220 fait aussi bien en Flac avec des sources HighRes audio (96khz/ 24 bits) que mon Dac Smsl su-1 connecté à un pc sans compression aucune. Incroyable !
This review has been posted for 1MII LAVAUDIO DS220 Bluetooth 5.1 Receiver QCC5125 DAC ES9018K2M aptX Adaptive LDAC
Qualité au rendez-vous
Excellente finition et connectique complete.
A 3 metres du recepteur la transmission Blutooth avec mon smartphone est établie en moins d'une seconde et en qualité Ldac. Avec des fichiers Flac qualité CD, sur mes enceintes de bibliothèque et mon ampli de classe A/B, je n'ai trouvé aucune différence 'qualitative' entre les CDs et ce petit transmetteur. Les bois, les cordes grattées frottés ou frappées, les cymbales, les grosses caisses... Tout est precis, net et bien positionné.
C'est bien bien mieux que mon précédent transmetteur aptx.
This small, practical and compact 1Mii Lavaudio DS220 Bluetooth 5.1 receiver brings wireless connectivity to your HiFi system. Its high-quality...
