Pour completer mon precedent avis, le Ds220 fait aussi bien en Flac avec des sources HighRes audio (96khz/ 24 bits) que mon Dac Smsl su-1 connecté à un pc sans compression aucune. Incroyable !
This small, practical and compact 1Mii Lavaudio DS220 Bluetooth 5.1 receiver brings wireless connectivity to your HiFi system. Its high-quality design is based on the combination of a Qualcomm 5125 Bluetooth receiver and an ES9018Q2M DAC chip, enabling you to enjoy precise sound reproduction even when wireless. The receiver also supports the high-resolution transmission codecs aptX, aptX HD, aptX Adaptive and LDAC, ensuring excellent sound quality over Bluetooth. The DS220 also features a small OLED display on the front panel, showing information such as the active input, the codec used, the sampling rate of the current stream or the selected filter.
| Specifications | |
| Product type | Bluetooth receiver |
| Bluetooth chip | Qualcomm QCC5125 |
| DAC chip | ESS ES9018K2M |
| Inputs | Bluetooth 5.1 1* USB-C |
| Outputs | 1* Optical Toslink 1* Stereo RCA |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, aptX Adaptive, LDAC |
| General | |
| Supply voltage | 5VDC 1A (power supply included) |
| Housing material | Aluminum |
| Dimensions | 76*87*25mm |
| Weight | 110g |
| Color | Black |
| Package | 1* 1Mii Lavaudio DS220 1* Bluetooth antenna 1* 5V 1A Power supply 1* Power cable 1* USB-A to USB-C cable 1* Optical Toslink cable 1* RCA to Jack 3.5mm cable 1* RCA cable |
| Input | USB |
| Input | Bluetooth |
| Output | RCA |
| Output | Optical Toslink |
| DAC / ADC Chip | ES9018K2M |
| Color | Black |
| Transmission / Reception protocol | Bluetooth |
| Supported Bluetooth codecs | aptX HD |
| Supported Bluetooth codecs | LDAC |
| Supported Bluetooth codecs | SBC |
| Supported Bluetooth codecs | aptX |
| Supported Bluetooth codecs | aptX Adaptive |
| Supported Bluetooth codecs | AAC |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Pierrick R.
Pierrick R.
