ARYLIC BR10 Bluetooth 5.0 Receiver
The Arylic BR10 is a small Bluetooth receiver that will enhance your existing sound system. In addition to its Bluetooth 5.0 receiver functionality, which enables it to support aptX, aptX Adaptive and aptX HD high-definition codecs, it also features a USB DAC function.
Reference : 19600
49,00 €tax incl.
40,83 € tax excl.
Arylic BR10 Bluetooth 5.0 Receiver QCC3040  aptX adaptive aptX HD
Arylic BR10 picture
The Arylic BR10 is a small Bluetooth receiver that will enhance your existing sound system. In addition to its Bluetooth 5.0 receiver functionality, which enables it to support aptX, aptX Adaptive and aptX HD high-definition codecs, it also features a USB DAC function. In terms of connectivity, the Arylic BR10 is equipped with the essentials: a USB-C input, a USB-A (USB Host) input, a 3.5mm stereo line-in jack, as well as a Toslink optical output and a 3.5mm stereo line-out jack. The Arylic BR10 supports sampling rates up to PCM 24bit 192kHz. To top it all off, Arylic provides its free Go Control APP for easy device control, and even custom EQ settings. The Arylic BR10 therefore boasts a number of interesting features in a compact form factor that makes it easy to integrate into an existing sound system, and at a very affordable price.
Arylic BR10 highlights
Arylic BR10: Bluetooth 5.0
The Arylic BR10 benefits from a Qualcomm QCC3040 Bluetooth reception chip, enabling it to support AAC, SBC, aptX, aptX Adpative and aptX HD codecs over a range of up to 15m without obstacles. This Bluetooth chip offers stable reception and extended compatibility with devices from Bluetooth 4.0 to Bluetooth 5.4.
Arylic BR10 Bluetooth functionality
Arylic BR10 USB DAC function
Arylic BR10: USB DAC
Thanks to its USB-C input/power port, the BR10 can be used as a USB DAC. It supports sampling rates up to PCM 24bit 192kHz for the Toslink optical output and up to PCM 16bit 48kHz for its 3.5mm jack line output. So you can enjoy CD-quality audio streams, whether wired or wireless with the BR10.
Arylic BR10: simultaneous optical and 3.5mm jack output
The Arylic BR10 allows simultaneous signal transmission via its Toslink optical output and 3.5mm jack line output. This makes it easy to pair with a 2.1-channel sound system and enjoy immersive sound with an active subwoofer.
Arylic BR10 and 2.1-channel system
Arylic BR10: Go Control APP
The Go Control APP gives you easy remote control of the BR10, and access to a wide range of equalization settings for personalized sound according to the type of music being played and your tastes.
Arylic BR10 app
APCWorkbench
Arylic BR10: customize your sound experience
The ACPWorkbench tuning tool lets you customize your audio experience. With this tool, you can adjust frequency on each channel, adjust channel balance, customize deep EQ settings and more.
ACPWorkbench software sold separately. You can buy it on Arylic website.
Arylic BR10 remote control
Arylic BR10: IR remote control
The BR10 can also be controlled remotely by remote control, for the most pleasant user experience.
Arylic BR10 overview
1ON/OFF button
2Volume -
3Play / Pause
4Volume +
5Toslink optical output
63.5mm stereo jack line input
73.5mm stereo jack line output
8USB-A port (USB Host)
9USB-C input / Power port
Product typeBluetooth receiver
Bluetooth chipQCC3040
InputsBluetooth
1x USB-C input (DAC)
1x USB-A input (USB Host)
1x 3.5mm stereo jack input
Outputs1x 3.5mm jack line output
1x Toslink optical output
Supported Bluetooth codecsSBC, AAC, aptX, aptX Adaptive, aptX HD
Supported sampling ratesUSB DAC : PCM up to 16bit 48kHz
Input line level2Vrms max.
Line output level2Vrms max.
USB Host compatibilityFile systems supported: FAT16, FAT32, exFAT, up to 128GB
Supported formats: MP3, MP4, WMA, MOV, M4A, AAC, FLAC, APE
Bluetooth range15m
Power supply5V 1A via USB-C
Dimensions108 x 72 x 26.6mm
Weight89g
Package1x Arylic BR10
1x Remote control
1x Jack 3.5mm cable
1x RCA 2 to 1 cable
1x Power supply
1x USB-C cable
InputJack 3.5mm
OutputJack 3.5mm
OutputOptical Toslink
DAC / ADC ChipNC
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsAAC
ARYLIC BR10 Bluetooth 5.0 Receiver QCC3040 aptX Adaptive aptX HD
The Arylic BR10 is a small Bluetooth receiver that will enhance your existing sound system. In addition to its Bluetooth 5.0 receiver...
