Mise en route en trois minutes.
Aspect gadget mais pas l'utilisation
Le son est parfait sur tout le spectre
Je recommande vivement cet appareil
Audiophonics comme d'habitude très bon...
CSR8675 Bluetooth 5.0 apt-X HD
This Bluetooth receiver allows you to connect remotely an audio source capable of emitting bluetooth with any device equiped with a S/PDIF input. Its use is easy :
Efficient for its price range, the receiver loads a Bluetooth chip CSR8675 supports aptX HD. This technology supports sampling rates up to 24-bit / 48kHz with a 576kbps rate. The chip automatically adapts the compression ratio to make the most of available bandwidth and to prevent loss of resolution that is not absolutely essential to meet the needs of the protocol.
The digital outputs Pulse enjoy an audio isolation transformer PE-65612 to ensure a clean and intelligible signal.
The power of the device is very easy via a micro-USB female DC 5V port. The receiver loads its own input filter to avoid unnecessarily add noise to the audio signal.
Beware, the sector and the micro-USB adapter are not provided.
The apparatus is provided with an imposing Bluetooth antenna.
The latter ensures accurate reception and error.
| Specifications | |
| Type | Bluetooth receiver |
| Standard | Bluetooth 5.0 apt-X HD |
| inputs | Bluetooth |
| Outputs | SPDIF Coaxial Optical SPDIF |
| Sampling frequency | 24-bit / 48 kHz |
| antenna length | 17cm |
| Dimensions | 84x70x20mm |
| Power supply | 5V-DC micro USB port Female Cable not included |
| Input | Bluetooth |
| Output | Coaxial SPDIF |
| Output | Optical Toslink |
| DAC / ADC Chip | NC |
| Color | Black |
| Transmission / Reception protocol | Bluetooth |
| Supported Bluetooth codecs | aptX LL |
| Supported Bluetooth codecs | AAC |
| Supported Bluetooth codecs | aptX HD |
| Supported Bluetooth codecs | SBC |
| Supported Bluetooth codecs | aptX |
Average votes 4.5 / 5 12 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Noel C.
Hugo Z.
Bruno M.
Victor D.
Régis T.
