En soi concernant le BT il fait son job. En revanche l equalizer paramétrique bug puisqu on ne peut pas le sauvegarder ( bug Fiio connu et non corrigé honteux !
The FiiO BR13 is a Bluetooth receiver equipped with a high-performance DAC.
KEY FEATURES:
This BR13 Bluetooth receiver from FiiO is equipped with an ES9018K2M DAC chip, a QCC5125 Bluetooth version 5.1 receiver chip and a TPA1882 amplifier chip. Versatile and high-performance, it boasts a wide range of connectors, including Toslink optical, coaxial SPDIF and USB-C inputs, as well as two outputs: a stereo RCA line output and a Toslink optical output. This makes it compatible with a large number of Hi-Fi devices for easy integration into your sound system, chained directly to a DAC, power amplifier or active speakers, for example. It accepts 24-bit 96kHz resolution streams via its inputs, and is capable of reproducing a 2Vrms signal level via its RCA output.
The Qualcomm QCC5125 Bluetooth receiver chip enables FiiO's BR13 to support high-resolution Bluetooth codecs; SBC, AAC, aptX, adaptive aptX, aptX LL, aptx HD, LDAC. It supports multiple connections to up to 2 simultaneous devices for easy source switching. Low Latency mode (aptX LL) lets you use the BR13 to watch movies or play video games while avoiding latency effects.
Thanks to its control application, the BR13 gives you access to 7 presets and 2 types of EQ settings with 10 adjustable frequency bands. This feature allows you to customize your listening experience according to your tastes and audio source.
FiiO's proprietary technology enables the BR13 to upsample low-resolution streams up to 24Bit 96kHz via all its inputs, for quality sound reproduction.
The BR13 integrates high-quality components: a QCC5125 Bluetooth receiver chip, an ES9018K2M DAC chip and a TPA1882 amplifier chip. The combination of these three components guarantees quality sound reproduction. The ES9018K2M DAC chip is a 32-bit stereo chip from ESS Technologie specially designed for audiophile applications. In addition, the TPA1882 operational amplifier chip guarantees low distortion and noise levels. In terms of performance, FiiO's BR13 boasts an SNR > 112dB as well as a THD+N < 0.0008% on its non-Bluetooth inputs and a THD+N < 0.0018% in Bluetooth LDAC.
1 | RCA stereo line output |
2 | Toslink optical input |
3 | SPDIF Coaxial input/output |
4 | Toslink optical output |
5 | USB-C input |
6 | Bluetooth antenna |
Product type | Bluetooth Receiver |
DAC Chip | ES9018K2M |
Amplification chip | TPA1882 |
Bluetooth Chip | QCC5125 |
Inputs | 1x USB-C input 1x Optical Toslink input 1x Coaxial SPDIF input/output Bluetooth |
Outputs | 1x Optical Toslink 1x SPDIF Coaxial input/output 1x RCA stereo |
Supported Bluetooth codecs | AAC / SBC / aptX / aptX LL / aptX Adaptive / aptX HD / LDAC |
Multi-sources Bluetooth | |
Supported sample rates | Local: 32Bits 96kHz Coaxial input: 32Bits 192kHz Toslink input: 24Bits 96kHz Coaxial output: 24Bits 96kHz (upsampling x2) Toslink output: 24Bits 96kHz (upsampling x2) |
Screen | LCD |
LDAC BLUETOOTH RECEPTION AND RCA LINE OUTPUT MEASUREMENTS | |
THD+N | < 0.002% (1kHz / -0dB @ 10KΩ) |
Crosstalk | ≥ 98dB (1kHz / -0dB @ 10KΩ) |
Frequency response | 20Hz-20KHz |
SNR | ≥ 113dB (A-weighted) |
Noise floor | <5uV (A-weighted) |
RCA line output level | 2Vrms |
RCA LINE OUTPUT MEASUREMENTS (USB DAC INPUT/OPTICAL DECODING) | |
THD+N | < 0.0006% (1kHz / -0dB @ 10KΩ) |
Crosstalk | ≥ 108dB |
SNR | ≥ 114dB (A-weighted) |
RCA LINE OUTPUT MEASUREMENTS (SPDIF INPUT) | |
Crosstalk | ≥ 109dB |
Frequency response | 20-20KHz : damping < 1.9dB 20Hz-50KHz : damping < 1.2dB |
RCA line output level | 2vrms |
Power supply voltage | USB 5V 1A |
Dimensions | 98 x 96 x 26.5mm |
Net weight | 135g |
Color | Black |
Package | 1x FiiO BR13 Bluetooth receiver 1x USB-A to USB-C cable (Data) |
Input | Bluetooth |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | RCA |
Output | Optical Toslink |
Output | Coaxial SPDIF |
DAC / ADC Chip | ES9018K2M |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
Supported Bluetooth codecs | LDAC |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | aptX Adaptive |
Average votes 3.7 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Daniel S.
Pierre F.
