HIDIZS H2 Bluetooth 5.0 Receiver CSR8675 MAX97220 NFC UAT aptX-HD LDAC Silver
Extremely compact yet incredibly practical, the Hidizs H2 is a high-performance Bluetooth 5.0 receiver that will allow you to do without cables to enjoy your music. Simply pair the H2 with your smartphone to simply stream your music.
3.0 / 5
Reference : 14944
64,90 €tax incl.
54,08 € tax excl.
Hidizs H2
Bluetooth 5.0 Receiver CSR8675 MAX97220 NFC Silver
Hidizs H2 Récepteur Bluetooth 5.0 CSR8675 MAX97220 NFC Argent
Qualcomm CSR8675 Bluetooth Chip
Bluetooth reception is provided by a Qualcomm CSR8675 chip. This high-performance chip supports numerous high-resolution codecs such as aptX, aptX-Hd, aptX-LL and LDAC. You will thus be able to enjoy your music in a practical way, without making any concession as for the sound quality.
MAX97220 Amplifier
The H2 also includes a MAX97220 amplifier chip, specially selected to perfectly accompany the CSR8675 Bluetooth receiver chip. This amplifier provides low distortion and noise for accurate, rich, and dense playback.
Bluetooth 5.0
Bluetooth 5.0 offers excellent transmission speed and stability, while allowing a good reception distance. Ideal to enjoy a quality listening experience.
Noise cancellation technology
The H2 takes advantage of Qualcomm's 8th generation cVd noise cancellation technology. This technology helps reduce background noise during calls to ensure a clear conversation.
UAT & HiBy Blue
The UAT is a Bluetooth audio codec developed by HiBy to support sample rates up to 192kHz, with a bandwidth of 1.2Mbps.
Moreover, the H2 is compatible with the HiBy Blue application, displaying in real time the sample rate of the file being read and allowing access to an equalizer, gain levels or even firmware updates.
HiBy Blue Android Play Store HiBy Blue iOS App Store
Hidizs H2 Récepteur Bluetooth 5.0 CSR8675 MAX97220 NFC Argent<span id=" />
Design & Ergonomics
Sober, elegant and compact, the H2 is dressed in a resin frame. The control is simple and ergonomic, with only 3 buttons for pairing, volume control and playback. In addition, the H2 is able to automatically reconnect to the last paired device when it is turned on.
An LED indicator legibly displays the sample rate of the file being played back: green for files between 44.1kHz and 48kHz and blue for files between 88.2kHz and 192kHz.
The H2 is also delivered with a clip, allowing it to be attached to a pocket, for example, for practical use on the move.
Product typeBluetooth receiver
Bluetooth chupQualcomm CSR8675
Amplification chipMAX97220
Bluetooth versionBluetooth 5.0
Supported Bluetooth codecsUAT, aptX, aptX-HD, aptX-LL, LDAC, AAC, SBC, CVC
Power output2x 8mW @ 32Ω
Frequency response20Hz - 90kHz
THD+N0.008% (1kHz)
SNR92dB
Crosstalk768dB @ 32Ω
Recommended headphone impedance8-60Ω
LED Indicator
NFC Pairing
CompatibilityAndroid
Windows
Mac OS
iPad OS
USB DAC FunctionUSB-C
Output1x Jack 3.5mm
Transmission distanceApprox. 10m
Battery capacity160mAh
Battery life7h
Charging time1.5h
Dimensions32 x 32 x 10mm
Weight12g
Housing materialResin
ColorSilver
Package1x Hidizs H2
1x USB-C Cable
1x Rear clip
OutputJack 3.5mm
DAC / ADC ChipNC
ColorSilver
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX
Supported Bluetooth codecsAAC
Must have gotten a defective unit.
Neat, little bluetooth dac we've got here which sadly has been ruined with a bad battery, it lasts only around 4 hours max instead of the 10+ told on the info here.
This review has been posted for HIDIZS H2 Bluetooth 5.0 Receiver CSR8675 MAX97220 NFC UAT aptX-HD LDAC Silver
Extremely compact yet incredibly practical, the Hidizs H2 is a high-performance Bluetooth 5.0 receiver that will allow you to do without cables to...
