IFI Audio ZEN Blue 3 Bluetooth Receiver
iFi Audio's Zen Blue 3, successor to the Zen Blue 2, is a high-end Bluetooth receiver. It features a new Bluetooth chip, the QCC5181, the most advanced model in Qualcomm's 5100 series to date. This Bluetooth receiver chip enables it to support high-resolution codecs, SBC, AAC, aptX Lossless, aptX Adaptative, aptX HD, LDAC and LHDC for lossless wireless transmission. It is also capable of transmitting streams wirelessly to Bluetooth headphones or earphones.
Reference : 19542
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 23-05-2025.
IFI Audio ZEN Blue 3 Bluetooth 5.4 Receiver Balanced QCC5181 DAC ES9023 aptX Lossless aptX Adaptive LDAC LHDC
iFi Audio Zen Blue 3 picture
iFi Audio's Zen Blue 3, successor to the Zen Blue 2, is a high-end Bluetooth receiver. It features a new Bluetooth chip, the QCC5181, the most advanced model in Qualcomm's 5100 series to date. This Bluetooth receiver chip enables it to support high-resolution codecs : SBC, AAC, aptX Lossless, aptX Adaptative, aptX HD, LDAC and LHDC for lossless wireless transmission. It is also capable of transmitting streams wirelessly to Bluetooth headphones or earphones.
Added to this is an ESS ES9023 DAC chip with jitter eliminator, enabling a dynamic range of 112dB, as well as use of the ZEN Blue 3 as a USB DAC (24bit/96kHz). It also features an optical Toslink/coaxial input on 3.5mm jack (24bit 192kHz) and analog stereo RCA. iFi Audio has opted for a balanced circuit with stereo RCA, balanced 4.4mm jack and Toslink/coaxial optical output on 3.5mm jack. Not only does the Zen Blue 3 benefit from numerous technical improvements, it also boasts a new look to match the brand's other devices, and a much more comprehensive control interface on the front panel. All these features make it a device of choice.
IFI Audio ZEN Blue 3: Bluetooth 5.4
iFi Audio's Zen Blue 3 supports the high-definition codecs SBC, AAC, aptX Lossless, aptX Adaptative, aptX HD, LDAC and LHDC, thanks to its Bluetooth QCC5181 receiver chip, and is certified HWA (Hi-Res-Wireless Audio). The Zen Blue 3 is therefore able to receive CD-quality sound in wireless transmission (aptX lossless - 1200 kbps).
Bluetooth 5.4
IFI Audio ZEN Blue 3: Bluetooth codec comparison
DAC chip ES9023
IFI Audio ZEN Blue 3: integrated ES9023 DAC
The Zen Blue 3 can also function as a wired DAC, thanks to its digital/optical inputs and ES9023 DAC chip. It supports 24bit 96kHz PCM streams via its USB input and 24bit 192kHz streams via its optical/SPDIF input via 3.5mm jack.
IFI Audio ZEN Blue 3: quality components
The Zen Blue 3 incorporates a MAX97220 amplifier chip, a CT5302 DSP and the brand's proprietary OV series OPAs. These OPAs deliver extremely low noise, low distortion (0.0001%) and wide bandwidth. The balanced circuit design also helps reduce noise, crosstalk and interference for a clearer sound.
Interior photo of iFi Audio Zen Blue 3
IFI Audio ZEN Blue 3: a complete interface
iFi Audio Zen Blue 3 overview
1ON/OFF button
2Operating mode selection
3Bluetooth antenna
4Transmission mode & low latency
5Brightness and Bluetooth pairing
6Source selection
7Display codecs and PCM format
8Sampling rate kHz LED indication
9Balanced 4.4mm jack output
10RCA input
11Optical/SPDIF input on 3.5mm jack
12DC 5V power supply port
13RCA output
14Optical/SPDIF output on 3.5mm jack
15USB-C input
16Bluetooth antenna connector
Product typeBluetooth receiver
Bluetooth chipQCC5181
DAC chipES9023
DSPCT5302
Amplification chipMAX97220
OPACustom OV series
InputsBluetooth
1x USB-C
1x SPDIF/ Optical via 3.5mm jack
1x RCA stereo
Outputs1x Stereo RCA line output
1x Balanced line output 4.4mm jack
Bluetooth
Bluetooth standardBluetooth 5.4
Supported Bluetooth codecsSBC, AAC, aptX, aptX Lossless, aptX adaptative, aptX HD, LDAC, LHDC
Supported sample ratesUSB: PCM 24bit 96kHz
Optical/SPDIF 3.5mm jack: PCM 24bit 192kHz
Operating modesRX mode: Bluetooth reception
TX mode: Bluetooth transmission
DAC mode: Wired operation
Output voltageBalanced 4.4mm jack: 4.1Vrms (0dBFS@1kHz)
RCA: 2.05Vrms (0dBFS@1kHz)
Output impedanceBalanced 4.4mm jack: ≤ 102Ω
RCA: ≤ 51Ω
SNR109dB
DNR109dB (0dBFS @ 1kHz) +A
THD+N< 0.005% (10Kohm de charge @20-20kHz)
Power supplyUSB-C ou DC 5V/≥0.5A (centre +ve)
Energie consumption<1W
Dimensions158 x 115 x 35mm
Net weight447g
Package1x iFi Audio Zen Blue 3
1x Pair of RCA interconnect cables
1x USB-A to USB-C
1x Mains adapter
InputJack 3.5mm
OutputJack 4.4mm
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipES9023
ColorGray
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsAAC
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsHWA LHDC
iFi Audio's Zen Blue 3, successor to the Zen Blue 2, is a high-end Bluetooth receiver. It features a new Bluetooth chip, the QCC5181, the most...
