SHANLING MW200 Bluetooth 5.0 Receiver DAC Headphone Amplifier AK4377 CSR8675 MMCX
The Shanling MW200 is both a Bluetooth receiver, a DAC and a headphone amplifier in neckband format. It benefits from a very nice design quality in order to offer you a great sound quality. It has a MMCX connector to connect your headset or earphones. The MW200 will allow you to easily stream your music from your smartphone or tablet to the receiver. No need for a cable to connect your headset to your playback device.
Reference : 14696
119,00 €tax incl.
99,17 € tax excl.
Shanling MW200
Shanling MW200 Récepteur Bluetooth 5.0 DAC Amplificateur Casque AK4377 CSR8675 MMCX
The Shanling MW200 is a Bluetooth receiver, DAC and headphone amplifier in neckband format. It benefits from a very nice design quality to offer you a great sound quality. It has a MMCX connector to connect your headphones or your earphones. The MW200 will allow you to simply broadcast your music from your smartphone or tablet to the receiver. Thus, no need for a cable to make the link between your headphones and your playback device.
Shanling MW200 Récepteur Bluetooth 5.0 DAC Amplificateur Casque AK4377 CSR8675 MMCX<span id=" />
AKM AK4377A DAC
The conversion and amplification stage of the MW200 uses an AKM AK4377 chip. It offers an excellent sound reproduction, marked by a magnificent precision and a great richness of the audio message.
Bluetooth 5.0
The Bluetooth 5.0 reception of the MW200 is provided by a Qualcomm CSR8675 chip. This allows a stable reception of the signal. It is also compatible with the standard Bluetooth codecs SBC and AAC, but also with aptX HD/LL, LDAC and HWA LHDC. These last codecs allow a transmission of very high quality without delay, up to 24bit 96kHz for the LHDC.
High conductivity cabling
The cabling of the MW200 is optimized, integrating high purity OFC copper conductors with silver plating, ensuring a perfect conductivity.
MMCX Connectors & Autonomy
The MMCX connectors of the MW200 benefit from an excellent quality, with a gold plating for a good signal transmission but also an excellent resistance to oxidation.
The MW200 also has a good autonomy, with a continuous use in reading of 14 hours or 500 hours in standby. It also integrates the Quick Charge technology: only 10 minutes are enough for a use during 2 hours.
IPX4 Standard
With its IPX4 rating, the MW200 is resistant to splashing water and humidity.
Appairage NFC & Microphone Knowles
Pairing the Shaling MW200 to your smartphone can be done quickly and easily. Using the NFC protocol, all you have to do is bring the receiver close to your smartphone to pair it up.
The MW200 also features a high-quality Knowles microphone with cVc Noise Cancellation technology and the One-Click Assistant tool.
LED Indicator
An LED indicator on the MW200 makes it easy to see which Bluetooth codec is being used to transmit the signal:
  • LDAC : Green
  • HWA LHDC : White
  • aptX / aptX LL : Purple
  • aptX HD : Yellow
  • SBC : Blue
  • AAC : Cyan
Control App
The MW200 comes with a mobile application available on Android and iOS, allowing access to many parameters to adapt the sound reproduction to your listening: digital filters, balance, equalizer... all this can be controlled simply from your smartphone.
One-click updates
With the Shanling Controller App, you can also update the MW200 to the latest firmware with one click.
OTA updates are only available for Android devices.
Product typeBluetooth receiver
DAC
Headphone amplifier
DAC / Headphone amplifier chipAKM AK4377A
Bluetooth chipQualcomm CSR8675
Bluetooth version5.0
Supported codecsLDAC, HWA LHDC, aptX HD, aptX LL, AAC, SBC
Power27mW @ 32Ω
SNR119dB
ConnectorsMMCX
Cable conductorsSilver plated Copper
Microphone brandKnowles
Water resistance ratingIPX4
Battery capacity360mAh
Autonomy in operationUp to 14h (SBC)
Up to 11h (LDAC)
Standby autonomyUp to 500h
ChargingVia USB-C
Neckband materialSilicon
NFC Pairing
Mobile appAndroid, iOS
OTA Updates
USB DAC FunctionUp to 16bit 48kHz
OutputMMCX
DAC / ADC ChipAK4377
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX
Supported Bluetooth codecsHWA LHDC
Supported Bluetooth codecsAAC
Récepteur bluetooth Shanling
Tour de cou malin, pratique et efficace. Marié avec des intras tinfi P1exigeant en terme de puissance, la bête s'en sort correctement.
This review has been posted for SHANLING MW200 Bluetooth 5.0 Receiver DAC Headphone Amplifier AK4377 CSR8675 MMCX
The Shanling MW200 is both a Bluetooth receiver, a DAC and a headphone amplifier in neckband format. It benefits from a very nice design quality in...
