SMSL B200 DAC USB Bluetooth Receiver
The SMSL B200 offers both USB DAC and Bluetooth receiver functions. It benefits from a Cirrus Logic CS43131 chip, enabling it to support sampling rates up to PCM 24bit 48kHz via its USB-C input. As a Bluetooth 5.1 receiver, it supports the high-resolution codecs aptX, aptX HD and LDAC.
Reference : 19773
99,00 €tax incl.
82,50 € tax excl.
SMSL B200 DAC USB CS43131 Bluetooth 5.1 Receiver aptX HD LDAC 24bit 48kHz
SMSL B200 picture
The SMSL B200 offers both USB DAC and Bluetooth receiver functions. It benefits from a Cirrus Logic CS43131 chip, enabling it to support sampling rates up to PCM 24bit 48kHz via its USB-C input. As a Bluetooth 5.1 receiver, it supports the high-resolution codecs aptX, aptX HD and LDAC. Its interface offers the essentials, with a USB-C input that doubles as a 5V 1A power port, a coaxial output, a Toslink optical output and an analog RCA output. The 2Vrms RCA output level enables the B200 to be coupled directly to active speakers or a power amplifier. It features an original form factor and a 2.33” color display showing the title and artist of the track currently playing, as well as information such as file format, Bluetooth codec and active input.
Caution: the B200's power supply via its USB-C port must not exceed 5V.
SMSL B200: USB DAC
The B200 features a Cirrus Logic CS43131 DAC chip, enabling it to maintain a THD+N of 0.0002% and achieve an SNR of 128dB. This DAC chip also enables it to support sampling rates up to PCM 24bit 48kHz via its USB-C input.
CS43131 DAC chip picture
SMSL B200 Bluetooth function
SMSL B200: high-performance Bluetooth receiver
The B200's Qualcomm Bluetooth 5.1 receiver chip supports high-definition codecs: SBC, AAC, aptX HD (576kpbs) and LDAC (990kpbs).
SMSL B200 overview
SMSL B200 overview
12.33-inch color display
2Multifunction button
3Bluetooth antenna
4RCA output
5SPDIF coaxial output
6Optical toslink output
7USB DAC input/Power supply port 5V 1A
Product typeUSB DAC
Bluetooth receiver
DAC chipCirrus Logic CS43131
Input1x USB-C input
Bluetooth
Output1x RCA stereo analog output
1x Coaxial SPDIF output
1x Toslink optical output
Output level2Vrms
THD+N0.002% (113dB)
Dynamic range / SNR128dB
USB compatibilityWindows 7-11 (with driver)
MAC OSX10.6 et +, Linux
Supported sample ratesUSB : up to PCM 24bit 48kHz
Supported Bluetooth codecsAAC (16bit/44.1kHz, 320kpbs)
SBC (16bit/44.1kHz, 328kpbs)
aptX (16bit/48kHz, 352kpbs)
aptX HD (24bit/48kHz, 576kpbs)
LDAC (24bit/96kHz, 990kpbs, 660kpbs, 330kpbs)
Power supply5V 1A via USB-C
Power consumption< 1W
Standby : < 0.1W
Dimensions72 x 108 x 72mm
Weight375g
Package1x SMSL B200
1x USB-A to USB-C cable
OutputCoaxial SPDIF
OutputOptical Toslink
DAC / ADC ChipCS43131
Max sampling rate48kHz
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX
Supported Bluetooth codecsLDAC
performant.
Acheté pour remplacer un Audiophonics U sabre , il tient bien la comparaison, son très clair et ciselé dans les médium et les aigus.
Mise en route rapide après avoir installé les pilotes ( lien fourni par l'assistance Audiophonics, merci ...) ça fonctionne direct en USB,
Apparié en Bluetooth en un éclair, pour écouter via le téléphone, à l'occasion.
J'ai utilisé les sorties RCA en analogique donc pas de retour concernant les sorties numériques,
En résumé très bon achat pour moi, en espérant une durée de vie aussi longue que le Sabre (8 ans!).
Très bon rapport qualité-prix pour ce DAC compact!
This review has been posted for SMSL B200 DAC USB CS43131 Bluetooth 5.1 Receiver aptX HD LDAC 24bit 48kHz
The SMSL B200 offers both USB DAC and Bluetooth receiver functions. It benefits from a Cirrus Logic CS43131 chip, enabling it to support sampling...
