Optical Fiber HDCP 2.2 4K HDR ARC 30m
This HDMI 2.0 cable integrates fiber optic bundles as conductors. These ensure an excellent transmission rate of up to 18Gbps, very good signal stability and extremely low attenuation, while allowing the signal to be free from harmful electromagnetic interference. The cable is capable of transmitting 4K / UHD video signals at 60Hz and supports 3D, HDR ARC, and HDCP 2.2 technologies. Its connectors are gold plated to improve the durability of the product by giving them a very good resistance to corrosion and oxidation.
Product type | HDMI 2.0 Cable |
Conductors | Optical fiber Copper |
Connectors plating | Gold |
Length | 30m |
Shielding | Aluminum foil |
Cable diameter | Ø4.5mm |
Supported resolution | 4K*2K @ 60Hz |
Bandwidth | 18Gbps |
Supported technologies | HDR UHD HDCP 2.2 ARC 3D |
Connectors body dimensions | 38 x 17.2 x 8.85mm |
Sheath material | PVC |
External sleeve material | PET |
Length (m) | 30.0 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | HDMI |
Conductors material (Cable) | Optical Fiber |
Conductors Plating (Cable) | None |
