VIABLUE FILTER 11 Filtering Ferrite Reducer Ø10.5mm to Ø10mm
Viablue Ferrite Reducers eliminate high-frequency electromagnetic interference (EMI) and the noise it induces within your audio cables. This is essential for designing high quality HiFi cables, providing a clean signal for optimal sound reproduction.
Reference : 5087
18,00 €tax incl.
15,00 € tax excl.
Shipping date: 22-09-2026.
Viablue Filter 11
Filtering Ferrite Reducer Ø10.5mm vers Ø10mm
https://www.audiophonics.fr/images2/899/899_splitter_y.jpg
These ferrites are very easy to install, by sliding over the cable and fixing with two M4 1.5mm hexagon socket screws.
Ferrite is a ceramic material composed of Iron Oxide and other metallic elements. All of them are electrically non-conductive, making it a very good insulator.
List of Viablue Filter models
LengthExternal diameterInput diameterOutput diameterRecommended cable model
Ferrite Filter 940mm20mm9.5mm9mmNF-S1 Silver
Ferrite Filter 1140mm20mm10.5mm10mmS-920 Silver
Ferrite Filter 1440mm24mm14.5mm14mmX-25 Silver
Ferrite Filter 1642.5mm26mm16mm15.5mmX-40 Silver
Ferrite Filter 1844.5mm29.5mm18.5mm17.5mmX-60 Silver
Ferrite Core 928mm16mm9.5mm9.5mmNF-A7
Product typeFerrite reducer
Accepted cable diametersØ9.1mm to Ø10mm
Input diameter10.5mm
Output diameter10mm
Length40mm
External diameter20mm
Mounting system2 hexagon socket screws M4 1.5mm
MaterialFerrite
Length (m)Sold by length
Max cable diameter (mm)10.0
Section (mm²)N/A
Conductors material (Cable)N/A
2 reviews
Des ferrites de qualité
Très belle fabrication, j'en utilise dans des dimensions différentes et j'avoue que ces ferrites sont d'excellente qualité.
This review has been posted for VIABLUE FILTER 11 Filtering Ferrite Reducer Ø10.5mm to Ø10mm
visuellement flatteur
lourd et bien fini la ferrite n'apporte pas, de mon point de vue, une quelconque modification du son... tant mieux. Assurez-vous d'avoir bien pris vos dimensions avant d'acheter ce produit, les côtes sont serrés.
très joli rendu visuel, ça fait sérieux.
Viablue Ferrite Reducers eliminate high-frequency electromagnetic interference (EMI) and the noise it induces within your audio cables. This is...
