NEOTECH NEP-3001G Power Cable Copper G-UPOCC Graphene 3x5.2mm² Ø16mm
Neotech's NEP-3001G is a power cable incorporating 3 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene makes it possible to improve the stability of electrical signal transmission at high temperatures while preserving the exceptional conductivity of OCC copper, enabling performance to remain intact, even at high voltages.
Reference : 19367
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 12-05-2026.
Câble vendu au mètre
NEOTECH NEP-3001G : Front view
NEOTECH NEP-3001G : sectional view
The conductors have CL3 PVC insulation, preventing any transmission of electrical discharge created by the double Mylar/aluminium shielding and braided tinned copper. The whole assembly is encased in a robust, flexible PVC sheath.
Product typePower cable
Number of conductors3
Conductors materialCopper with graphene G-UPOCC
Cable diameterØ16mm
Insulation materialPVC CL3
ShieldingAluminised Mylar
Braided tinned copper
Cross section3x5.2mm² / 10 AWG
ColorPurple
PackageSold per metre
Diameter (mm)16.0
ShieldingYes
Section (mm²)5.2
Conductors material (Cable)Graphene
Ground / ShieldingYes
5 reviews
Nep-3001G; Nep-3002G
Oba przewody są identycznej budowy, geometrii i wykonane z tego samgo materiału. Niezależnie od ceny przewodów, oceniam je pod wpływem brzmienia na bardzo wysokim poziomie. Rozdzielczość, dzwięczność, sprężystość i rozciągniecie basu jest na bardzo wysokim poziomie. Przstrzeń i lokalizacja instrumentow w polu dzwiękowym jest bardzo dobra. Polecam więc i pełna rekomendacja.
This review has been posted for NEOTECH NEP-3001G Power Cable Copper G-UPOCC Graphene 3x5.2mm² Ø16mm
Remarquable câble !!
Une superbe fabrication, un montage délicat car câble assez rigide à prendre en compte si l'espace est limité derrière les appareils. Mais quel son naturel, précis, dynamique, une très belle ampleur et une douceur des timbres tout en ayant une grosse résolution et une neutralité certaine, contrairement à une autre marque très réputée en DIY !!! Je terminerai par sa polyvalence où, malgré le diamètre de ses conducteurs, il va aussi bien sur l'ampli que sur des appareils numériques, preuve de la qualité de son cuivre !! A recommander sans réserve, les limites étant données par la connectique et pas par le câble. Bravo Neotech.
Mieux avec le HE9 MKII
Après un essai pas tout à fait satisfaisant sur l'ampli Master-3, le câble se révèle comme un excellent cordon d'alimentation pour le HE9 mkii d'Audio-gd. Rien ne manque, le son est riche, plein et suffisamment neutre. Aucune faiblesse ne ressort. Seul un brin de vivacite pourrait être ajouté (pour faire le difficile). Cela n'affecte aucunement la clarté ni la musicalité. J'ai utilisé des prises Monosaudio pure cuivre avec placage de rhodium. Celles-ci ajoutent certainement un peu d'énergie dans les hautes. Je conseille donc des prises avec ce genre de sonorité. Ce câble demeurera dans ma chaîne.
Excellent mais...
Ce câble offre une balance tonale équilibrée. Mais associé à l'amplificateur Audio-gd Master-3, il manque de présence dans le haut du registre, un peu d'éclat, bref. Ce n'est pas que le rendu n'est pas impressionnant. Le médium est fouillé, l'image stéréo large, la basse profonde et généreuse. Peut-être est-ce un manque de rodage, le câble à environ 230h au compteur. Je n'ai pas renoncé à l'intégrer à ma chaîne puisque je le considère tout de même excellent. A suivre.
No brainer
Think this is one of the best cables for the money at the moment. Together with NEOTECH NC-P312G MKII Schuko + NEOTECH NC-P303II Connector IEC C13. It gave my NAD M23 a great boost. The graphene in the cable and the connectors will make the difference here I think. In my opinion it is not inferior to the Furutech dps-4.1. Highly recommended.
Neotech's NEP-3001G is a power cable incorporating 3 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new...
