YARBO SP-1100PW Triple Shielded Power Cable OCC 5.53mm² Ø16.5mm
4.6 / 5
Reference : 6456
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 23-06-2026.
Câble au mètre
This cable consists of 3 conductors of large cross-section, has a double shielding against electromagnetic interference
This shielding is composed of a layer of PTFE per strands as well as a braid of copper shielding.
Each conductor is composed of several 7 strands of monocrystalline OCC copper (black and red), the earth of 3.
They are insulated with a layer of PTFE, copper strip then PVC./ P>
Despite its diameter of 16.5mm this cable is relatively flexible
It will guarantee a dynamic and detailed sound reproduction.
Features:
  • Phase and Neutral conductors: 7x1 mm = 5.53 mm² OCC insulation PTFE + copper strip + sheath PVC
  • Earth conductors: 4x1 mm = 3.16 mm² OCC insulation PTFE + strap copper + sheath PVC
  • The ensemis again shielded by a copper strip and a thick PVC sheath
  • https://www.audiophonics.fr/images2/6456/6456_YARBOSP1100PW_1.jpg
    https://www.audiophonics.fr/images2/6456/6456_YARBOSP1100PW_2.jpg
Diameter (mm)16.5
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)5.53
ConnectorN/A
Ground / ShieldingYes
40 reviews
Nice power cable
Really nice quality power cable.
Fairly time consuming to strip, but not difficult. The way the cable is separated by different layers of insulation and shielding makes this a very quiet power cable.
I used this to make an extension block with 4 Schuko sockets.
This review has been posted for YARBO SP-1100PW Triple Shielded Power Cable OCC 5.53mm² Ø16.5mm
Remplace allègrement mes câbles très haut de gamme
Sur les recommandations d'un amis , j'ai équipé tous mes composants avec ce câble , et après une période de Rodage d'une vingtaine d'heure , ces câbles ont tous simplement changer radicalement mon système.
Les graves , le détourage des instruments et la scene sonore ont tous été bonifiés de façon extrêmement significative. Bref mes câbles précédent ont été renvoyés au rang de reliques. Merci à audiophonics !
One of the best D.I.Y. power cables
After a very long burn-in time, I share the other reviewers praise of the cable. I use copper / rhodium plugs in both ends, but it is system depend, whatever plugs you choose.
Sans intérêt
Monté avec des fiches Viborg haut de gamme plaquées argent, ce câble est gras et terne.
Après 200 h de rodage il n'y a pas eu d'amélioration. Je me suis laissé tenté suite aux différents avis très élogieux mais le résultat est très décevant.
Bande passante restreinte, beaucoup de grave mais un grave lourd, un medium/aigu mate pour ne pas dire terne …
Vraiment à éviter surtout au vu du prix qui ne justifie absolument pas son achat. Je l'ai remplacé par un Cardas Clear Power et c'est le jour et la nuit.
Certes le Cardas est beaucoup plus cher. Le Yarbo SP 1100PW était monté sur un préampli Mark Levinson 38S.
Je l'ai installé sur une alimentation Sbooster et la c'est moins mauvais. Du Furutech ou de l'Oyaide donneront des résultats bien supérieurs et ce sans forcer !
A méditer avant tout achat pour éviter de perdre du temps et de l'argent !
 (4)
 (7)
YARBO SP-1100 PW
Une autre planète pas la peine d'aller plus loin wow WOW c'est quoi ce câble YARBO IL Y A QUOI dans le câble rapport qualité une tuerie monté avec les Viborg je suis bouche B je recommande à 10000000%.
Un peu long à monter mais le résultat est là.
YARBO J'y suis j'y reste un point c'est TOUT je vais commander d'autres c'est sur WOW WOW!! merci encore Audiophonics
 (3)
